Bush hog drops when engine is shut off
   / Bush hog drops when engine is shut off #1
jmonroew71
Axton, VA
1954 Ford
I am a newbie to owning a tractor and I have a 1954 Ford 640. When I first crank it up the tractor lifts the bushog just fine. After about 30 minutes of running it will no longer lift the mower off of the ground. Also, when I cut it off the mower drops straight to the ground. This is relatively new problem. Any ideas will be greatly apprecitated.
Jason
   / Bush hog drops when engine is shut off #3
time to chase an oil leak. most likely source is a blown lift piston oring.
also.. does your machine have a sqaure vane pump or a cylindrical piston pump.
post back
John Deere 637 Disk (A50514)
John Deere 637...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
2008 CATERPILLAR 430E BACKHOE (A51242)
2008 CATERPILLAR...
2022 KUBOTA SVL75-2 SKID STEER (A51242)
2022 KUBOTA...
1272 (A50490)
1272 (A50490)
