Bush hog drops when engine is shut off
   / Bush hog drops when engine is shut off #1
jmonroew71
Axton, VA
1954 Ford
I am a newbie to owning a tractor and I have a 1954 Ford 640. When I first crank it up the tractor lifts the bushog just fine. After about 30 minutes of running it will no longer lift the mower off of the ground. Also, when I cut it off the mower drops straight to the ground. This is relatively new problem. Any ideas will be greatly apprecitated.
Jason
   / Bush hog drops when engine is shut off #3
time to chase an oil leak. most likely source is a blown lift piston oring.
also.. does your machine have a sqaure vane pump or a cylindrical piston pump.
post back
INGERSOLL RAND 100KW GENERATOR (A50854)
INGERSOLL RAND...
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
2017-2022 Ford F-250/350 Rear Bumper (A49461)
2017-2022 Ford...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
CAT 430E BACKHOE LOADER (A50854)
CAT 430E BACKHOE...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
