CobyRupert
Super Member
Can you see the pto shaft (on the tractor side of any shear bolt) slow down when the blades slow down? This means the pto is probably slipping inside the tractor.
If the tractor’s pto shaft rpm stays consistent with the tractor engine’s rpm but the blades slow down, the slippage is elsewhere on the mower. Some shear bolts can be broke and look okay if the sheared head doesn’t fly out.
Like roadworthy says, check adjustment of pto clutch.
