Bush Hog BH27 too big for MX5800?
   / Bush Hog BH27 too big for MX5800? #1
Hozzie
Chapel Hill, TN
M7060
I am in the market for a Rotary Cutter for my MX5800 with 50 HP PTO. After some research I was planning to order a Woods BB720 (6'). Just looking at CL and there is a BushHog BH27 (7') available with limited use which has a good price. My concern is the BH27 may be a bit too much cutter for my machine. The website says it recommends 55HP PTO. I do have my tires as far out as I can go, so the extra foot would be nice to cover the tracks, but not if I will be wrestling with it.
General terrain is rolling hills with some woods undergrowth cutting, but mostly just regular pasture maintenance. I am not mowing 20 acres, so the extra width for time savings isn't a big concern.
I can probably get the BH27 for $1000 less than the BB720.
Thanks for your insight.
   / Bush Hog BH27 too big for MX5800? #2
I ran a 6 foot rotary cutter on my 38 hp kubota without any issues at all. Handled it just fine. Only reason I downsized to a 5 foot was because I needed to fit into tighter spacers.
   / Bush Hog BH27 too big for MX5800? #3
I run a 7’ finish mower behind mine and it doesn’t even know it’s back there, wish I had a gear splitter for it so I didn’t have to run the tractor at such high RPMs:eek:
   / Bush Hog BH27 too big for MX5800? #4
I run a six foot LandPride behind a L4240 Kubota(44 H.P.),no problem.You should be about to handle a 7' for light duty clipping for sure.You may need to keep the loader on or run front weights.
   / Bush Hog BH27 too big for MX5800? #5
I purchase a new Bush-Hog branded rotary cutter in 2004;it has been used on three different tractors and probably has at least 1200 hours of use;looks bad but still works fine.This one has a shear pin;the larger ones use a slip clutch;service every spring and you will have no problems.
That 7 footer weighs about 1300 lbs.
   / Bush Hog BH27 too big for MX5800? #6
If you're cutting very low the 6' will cut better (less scalping) than the 7'. You also might want to compare blade tip speed of both to help decide.
   / Bush Hog BH27 too big for MX5800? #7
50PTO HP should be more than enough to run that cutter. I suspect the reason they suggest a high HP is for weight more than power necessary to run that machine. A 50HP PTO machine can run a 12' batwing as long as you're not trying to cut 3' grass, you'll be fine, just slow it down a little. It's much nicer to run slower anyway, less abusive to the driver and the gear than using a smaller cutter and running 10MPH to try to keep the machine working hard. I'd say go for it. The only reason I don't have a 7-8' fixed deck cutter with my 50HP PTO machine is because my land is too hilly, I need a floating deck to keep from scalping. Even my 6' is hard to deal with at times if I want to cut down close to the ground. But this is a problem on any large fixed cutter and not related to your original question; I think you'll be fine with that machine and have plenty of power to cut quickly with it.
Thanks for all of the replies. After looking more and reading a bit more, I think I am just going to go with the BB720X. I do have fluid in the tires and don't foresee taking off my loader in most cases, so weight hopefully isn't an issue, but it weighs ~100lb's less and has a tip speed of 15,900 which is 1,500fps faster than the BH27. It should also be a bit easier to maneuver in tight spaces, albeit minimally. If I want to mow faster later, I will look into one of the low HP 12' batwings.
Thanks again.
   / Bush Hog BH27 too big for MX5800? #9
ran a 6' hd Bush Hog on an MX500. good match. would much rather go hduty 6' on a tractor your size than a mid or light duty 7'. besides, a 7' hog imho is an odd size to be avoided. with blades that size, you're going to get a lot of vibration hitting stuff and not the quality cut of a 6'.
am sure some will disagree, just my take
   / Bush Hog BH27 too big for MX5800? #10
I just went through this decision making with what to put behind my Kubota M7060. I was really leaning towards a 7' rotary cutter as anything larger was out of my budget. As I read more, I ended up going with a 6' Titan 1606 with chains. The specs on the deck looked better than the Bush Hog BH26 I was looking at and it was considerably less expensive. The 7' cutters are large and I know I'll be cutting some thick stuff initially. The land I cut in east TN is hilly in the front and I wanted more maneuverability in tight spots. At some point later, I might purchase a larger pull-type cutter for the pasture.
EZGO (A50324)
EZGO (A50324)
Ford 5610 (A50120)
Ford 5610 (A50120)
P.T 500 Gallon Spray Rig (A50120)
P.T 500 Gallon...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
Duetz Power Unit (A50121)
Duetz Power Unit...
