Rotary Cutter Bush Hog BH16 vs Landpride RCR1872
   / Bush Hog BH16 vs Landpride RCR1872 #1
shajoe44
North Augusta, SC
Kubota MX5000
Ive narrowed my search down to these 2 mowers. Any suggestions as to one over the other?
Thanks
   / Bush Hog BH16 vs Landpride RCR1872 #2
I don't think you could go wrong either one. They both have good reputations. I might lean towards the land pride because I like the straddle mounted pin hookup for the 3pt lower links better than the cantilever style on the BH.
Can you explain what the differences are in what you described. I am not exactly what you are trying to say as to what one does over the other.
Thanks
   / Bush Hog BH16 vs Landpride RCR1872 #4
Well the straddle style captures your three point arm on each side where and you slide a pin through the arm. The cantilever style has the pin bolted to the cutter and you slide the lift arm on the pin. I find the straddle style easier to hook up and by all rights it is stronger. However...I've never had a problem with bush hogs set up as far as being weak. I looked at both of these cutters but ended up with a 172 Rhino mainly because I've always wanted to try a Rhino product.
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
2021 Ford F-250 Crew Cab Pickup Truck (A55852)
2021 Ford F-250...
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55301)
Koyker Loader...
John Deere 7410 (A53317)
John Deere 7410...
