Backhoe Bush hog 750H Backhoe on Kuboat L4300DT
   / Bush hog 750H Backhoe on Kuboat L4300DT #1
zkubota
Arkansas
Kubota L4400
Dad is wanting to put a backhoe on the aforementioned tractor. The dealer recommended the 750H (was 765H). What can anyone tell us about this combination. It will not be used to dig ponds, canyons, etc, nor will it be used daily. Maybe once a month. Mostly to clean out ditch lines, dig/repair utilities.
My concern is about hard a 3pt backhoe is on the tractor chassis. I know they make them for tractor, but seems like a lot of dynamic forces on the tractor, that might not have been accounted for.
Any thoughts, suggestions, price estimates?
thanks in advance.
   / Bush hog 750H Backhoe on Kuboat L4300DT #2
I have the Bush Hog 750 mounted to my TC30. There are some pictures in my gallery. Mine is subframe mounted and still can move the tractor around some. If they have a subframe kit for your model tractor I would get it.
Mine was around $6100 nearly 2 years ago. Came with 18" bucket, subframe and rear remote for hydraulics. I also bought a 12" bucket for around $400.
Good luck with your purchase.
Rodger
They do offer the subframe kit.
Anyone else?
Only one response? Surely someone else has something to add? :(
   / Bush hog 750H Backhoe on Kuboat L4300DT #5
I have a Woods 750 BH on the back of a JD 4500 only using the 3pt, both BH and tractor are similiar to your dads. I bought the BH used and they recommended the sub frame hitch, I still haven't added it and that was 3-4 years ago and used it quite abit for various digging activities. I only run the RPM between 1500-2000, the cycles are plenty fast and power is enough for me. I am concerned that I may hurt the tractor but I don't push it. Not sure if this helps- its my 2 cents.
   / Bush hog 750H Backhoe on Kuboat L4300DT #6
In spring 2006 I posted several questions asking about mounting a 3ph BH on my NH TC26DA. The dealer (I bought the tractor and BH new together) said the 3ph would be no problem, but about 98.3% of respondants on this site said "NEVER get a 3ph mounted BH". Our area is flat but rocky and I wanted ground clearance and ease of mount/dismount so I went with the 3ph mount. After about 30 hours use (only maybe 10 using the bh) I developed a leak in the rear transmission area - lost about a quart overnight. They picked up the tractor and found a hairline crack in the housing, which required a complete rebuild of the backend and replacing the housing... all under warranty (buying new was a good move for me!). The dealer never admitted (or could tell) if it was the backhoe or just a defective casting. But I decided I didn't want this to happen again so I bugged the sales guy to replace the 3ph mount on my bh with the frame mount (which is about a $300 materials premium) and to configure my tractor. He worked a deal with the supplier (I have a Wallenstien BX600 hoe, it's great) to get the mounting hardware for the frame mount (the 3ph mount unbolts and the frame mount goes on its place) for no charge. I paid him $100 for labour to install the frame mount.
He delivered the whole thing back to me a week later and WHAT A DIFFERENCE. It is much sturdier with the frame mount, and although I lost about 2" in ground clearance when the hoe is mounted (virtually no loss when not mounted, just a couple of brackets under the tractor) it's REALLY worth it. It feels so much better using it, and I can see that the forces are no longer trying to tear the back end apart.
So my advice is the same as most others you'll find when you search for "3ph mounted backhoe" on this site...GET THE FRAME MOUNT.
The other reason - ease of mount and dismount - is also not a good reason to go 3ph. Mine needs me to take off the 3ph arms (remove 6 clevis pins, 1 minute) then back the tractor up and connect the hydraulics. I need to then back carefully to align two hooks on the frame to go around the bottom 3ph pins on the tractor. I can use the stabilizer and dipper boom hydraulic controls to line up the hoe and get this pretty good within a couple of tries. Then I use the dipper boom to tilt the frame up to align the aforementioned brackets attached to the tractor frame to line up with holes at the front of the bh frame, and insert two more pins. It might take 10 minutes all told. Taking it off is even faster, less than 5 minutes. And this is on gravel (I have no paved areas on my property).
GO with the FRAME mount...please. As far as I see it there is no reason not to, and I admit I was wrong in choosing the 3ph the first time around. I have pics of the mounting if anyone's interested.
Briancd...good response thanks. I will let my dad know what I've learned.
HOMEMADE TREE STAND W/ STEPS (A51248)
HOMEMADE TREE...
2020 CATERPILLAR 279D3 SKID STEER (A51246)
2020 CATERPILLAR...
66in Light Material Bucket Skid Steer Connection (A53472)
66in Light...
2023 JOHN DEERE 8R370 LOT IDENTIFIER 187 (A53084)
2023 JOHN DEERE...
NORTHERN 3P-100 AG MIST SPRAYER (A51247)
NORTHERN 3P-100 AG...
UNUSED MOWER KING ECSSTR072-72" HYD TILLER (A51248)
UNUSED MOWER KING...
