Bush Hog 286/ 6 foot rotary cutter Questions
   / Bush Hog 286/ 6 foot rotary cutter Questions #1
MrJimi
Elite Member, Rest in Peace
NorthEast, Florida
Case 1845 C Skid steer
I need to know what is wrong with putting a RC/Bush Hog 286 that requires a 40 HP PTO to operate it on a 20 HP PTO HP machine?
I understand I will have to go slower and take smaller bites but that is fine with me for now. But will it work? Wife and I cut 4 foot tall grass with a 22 inch push mower and it worked, real slow but it worked. I am wanting your opinions and I can live with the slower and smaller bites.
And how many of you do this now and are almost pleased with the results.
Jim
   / Bush Hog 286/ 6 foot rotary cutter Questions #2
A rule of thumb I have heard is 5 HP per foot of cutter. If you are just mowing grass, it may work with 20HP depending on how much of that HP the tractor needs to cover the terrain and how wet the grass is. Of larger concern might be the weight of the 6' cutter hanging off the back of that 20HP tractor. Can you try before you buy?
   / Bush Hog 286/ 6 foot rotary cutter Questions #3
Jim
Can your 20 HP tractor SAFELY LIFT over 900 lbs that extends out over 7' from the rear of the tractor's hitch? If the 286 has saftey chains (which MOST do, as they're considered standard equipment) (Seems to me I recall 980 something lbs with chains)
I've got a 286 that I use on a 40(+)hp utility tractor that hits the scales over 5100lbs. Good chance my tractor is several feet longer than your 20 hp compact. Mine keeps the front end planted firmly on the ground, but I'd bet yours WON'T.
And that doesn't even take in to consideration the PTO load that far exceeds your tractors output.
If it was MY 20 HP tractor, I wouldn't try it.
   / Bush Hog 286/ 6 foot rotary cutter Questions #5
   / Bush Hog 286/ 6 foot rotary cutter Questions #6
6' bush hog on a 20hp tractor?
You're kidding, right?
If you really do try it, please report back with details of the result.
   / Bush Hog 286/ 6 foot rotary cutter Questions #7
MrJimi said:
I should add that I have a Case 1845 C Skidsteer and I will be mounting this on the front, my machine's weight is a little less than 7,000 pounds and here is the link for what I am looking at
http://www.skidsteersolutions.com/Skid_Steer_Motorized_3_Point_Adaptors_s/53.htm
Thanks and I should have put this in earlier, sorry
And I will be building my own adapter for this
Jim
Hydraulic motor-driven PTO to spin a 6 foot rotary mower??? I wouldn't count on it.
gabby
   / Bush Hog 286/ 6 foot rotary cutter Questions #8
Hmm.. there are some addative losses here.. going from engine to hydro pump to hydro motor to gearbox to blade.
What a bout a setup that used a hydro moto mounted where the gearbox used to be.. thus making it full hyd.. cut out the middleman and some of the ineficiency?
Soundguy
gabby
Soundguy
I have seen that done, how does gearbox drive blades? shaft,spline, bolted on.
I need to find out. Is there a site that has exploded view of this connection.
Thanks
Jim
   / Bush Hog 286/ 6 foot rotary cutter Questions #10
Jim
Sure you can run that hydraulic bush hog on a smaller hydraulic PTO . It will just run slower. Since most bush hog's run at around 540 rpm, on the 20 hp PTO, you will run around 270 rpm, Some people run their bush hogs slow anyway. I would keep the blades sharp.
GENERATOR HOUSE POEWERED BY TWIN 550HP (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
HEAVYEQUIPMENT ROLLS OF CONDUIT (A50854)
HEAVYEQUIPMENT...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
WHITE CI-7 DRAW WORKS POWERED BY TWIN DETROIT 12.7S (A50854)
WHITE CI-7 DRAW...
