Bush Hog 2240 QT loader
   / Bush Hog 2240 QT loader #1
Samtj
Muldrow, Oklahoma
Yanmar ym2210BD / 1947 Ford 8n
I have a 2 spool valve on my Bush Hog 2250qt loader that I need some specs on. I've done several searches with no luck. It's a Dukes Fluid Power 3527wg. Is it open? Pressure relief? I just don't know what I have. I'd appreciate any info you can give on it.
   / Bush Hog 2240 QT loader #2
Sam
Can you post a few pictures of the valve from different angles. I suspect that based on pictures we can determine if there is a relief in the valve and possibly whether open or closed center
   / Bush Hog 2240 QT loader #3
Make sure to get pictures of any casting identifications by the ports on the valve.
Aaron Z
   / Bush Hog 2240 QT loader #4
6 ports or 7? If 7 it is an open center valve with Power Beyond. If 6 it could be a simple open center valve or (less likely) a closed center valve. Apply compressed air to the pressure port with the spools centered. If 6 ports and air exits the return it is open center. 6 ports and no air exits it is closed center. 7 ports and air exits the PB port it is OC with PB.
Here is a picture of the tag. I'll snap a few more this evening and post them. I'll also do the air pressure trick and post my findings. Thanks
It's not pretty but it does function.
Yes it is in the list and has an exploded view of the parts but no info or specs that I could find.
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
UNUSED CFG INDUSTRIAL MH12RX EXCAVATOR (A51247)
UNUSED CFG...
UNUSED FUTURE HYD HEDGE TRIMMER (A51248)
UNUSED FUTURE HYD...
Bobcat Sweeper/Bucket  72"  (A52384)
Bobcat...
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
