Bush hog 109 blade timing
   / Bush hog 109 blade timing #1
Frisch
JD1540
I have an old, really old model 109 bush hog rotary cutter.
I need some information on blade timing. I'm assuming that the blade carriers need to be set 90 degrees from one another.
Can anyone help in solving the blade/gearbox alignment question.
Thank you.
I also noted that on the inside lip of the stump jumper there is a concave fixture that might be used for alignment.
   / Bush hog 109 blade timing #2
Is this a two spindle machine? If so you want one one set of blades 90* to the other so they will not hit, assuming they overlap.
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2020 JOHN DEERE 7R210 LOT IDENTIFIER 167 (A53084)
2020 JOHN DEERE...
UNUSED RAYTREE RMT48-48" TRENCHER (A51248)
UNUSED RAYTREE...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
