Bush hog 109 blade timing
   / Bush hog 109 blade timing #1
Frisch
JD1540
I have an old, really old model 109 bush hog rotary cutter.
I need some information on blade timing. I'm assuming that the blade carriers need to be set 90 degrees from one another.
Can anyone help in solving the blade/gearbox alignment question.
Thank you.
I also noted that on the inside lip of the stump jumper there is a concave fixture that might be used for alignment.
   / Bush hog 109 blade timing #2
Is this a two spindle machine? If so you want one one set of blades 90* to the other so they will not hit, assuming they overlap.
2024 JOHN DEERE 1025R LOT IDENTIFIER 150 (A53084)
2024 JOHN DEERE...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
UNUSED ALLMETAL K0311-10' GALVALUME STEEL (A51248)
UNUSED ALLMETAL...
2022 CATERPILLAR 272D3 SKID STEER (A51246)
2022 CATERPILLAR...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
10' CONTAINER (A51248)
