Burning up points and condensor
/ Burning up points and condensor #1
hangemhorns
hi newbie here.... i have a 1959 ford 841 with a 172 that has been converted to a 12 volt system....but i keep burning up points and condenser... if anyone could help please let me know what i need to do... it has a 12 volt alternator and 12 volt battery im not sure what else has been done but thats what i can see....thanks toby
/ Burning up points and condensor #2
Is the coil a internal resistance coil? It sounds like you are running a coil that is not equipped with an internal resistor and needs an external resistor. Coils are not intended to run on a full 12 volts.
Get an ignition dropping resistor also called a ballast resistor, at any automotive supply store. It is around 3 to 4 inches long made of ceramic with a wire wound resistor inside. Without it your points will burn up. KennyV
/ Burning up points and condensor #3
Or simply replace your coil with a coil that has an internal resistor. They are not that expensive--probably less than a couple sets of points. The ballast resistor will also work, but I personally just prefer the coil with the built in resistor.
Mike
/ Burning up points and condensor #4
forget the external resistor and 6v coil.. and don't even bother trying to find a modern coil that actually has an internal resistive element.
get a napa IC14SB.. it's about a $16 coil here in florida.. up north or on the other coast.. might be a few more bucks..
most of my ford gassers on 12v are running this coil. including an 850 and a 951, 541 naa.. etc.. all of these are using the 134/172 ci engines..
soundguy
