Burning up points and condensor
/ Burning up points and condensor #1
hangemhorns
hi newbie here.... i have a 1959 ford 841 with a 172 that has been converted to a 12 volt system....but i keep burning up points and condenser... if anyone could help please let me know what i need to do... it has a 12 volt alternator and 12 volt battery im not sure what else has been done but thats what i can see....thanks toby
/ Burning up points and condensor #2
Is the coil a internal resistance coil? It sounds like you are running a coil that is not equipped with an internal resistor and needs an external resistor. Coils are not intended to run on a full 12 volts.
Get an ignition dropping resistor also called a ballast resistor, at any automotive supply store. It is around 3 to 4 inches long made of ceramic with a wire wound resistor inside. Without it your points will burn up. KennyV
/ Burning up points and condensor #3
Or simply replace your coil with a coil that has an internal resistor. They are not that expensive--probably less than a couple sets of points. The ballast resistor will also work, but I personally just prefer the coil with the built in resistor.
Mike
/ Burning up points and condensor #4
forget the external resistor and 6v coil.. and don't even bother trying to find a modern coil that actually has an internal resistive element.
get a napa IC14SB.. it's about a $16 coil here in florida.. up north or on the other coast.. might be a few more bucks..
most of my ford gassers on 12v are running this coil. including an 850 and a 951, 541 naa.. etc.. all of these are using the 134/172 ci engines..
soundguy
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61568)
2016 Chevrolet...
Wooden Wagon Wheel Chair (A61569)
Wooden Wagon Wheel...
72in. Fork Extension (A61567)
72in. Fork...
UNUSED WOLVERINE TQH-26-01C QUICK HITCH (A62130)
UNUSED WOLVERINE...
New/Unused Landhonor Quick Attach Power Rake (A61166)
New/Unused...
KUBOTA M9000 TRACTOR (A62130)
KUBOTA M9000...
