Burning stumps
   / Burning stumps #1
challengertn
Bronze Member
Southern middle Tennessee
MF 135 soon to be Kubota
Anybody have any tips that would help when burning out stumps. These stumps are large and would take a dozer to dig out and they are in a place that would make the damage done by a dozer not worth getting rid of the stumps.
   / Burning stumps #2
Auger/drill a bunch of holes in them and maybe pour some kerosene in the holes, give it time to soak in good. Pile brush on top and get a good fire going all day long. Might take more than one burning.....I have had fair results with this method.
Ben
   / Burning stumps #3
My uncle drilled holes in some of his and poured something inside the hole (forget what it was). As I recall, he said it would either hasten the deterioration from the inside... or that it was flammable and he was going to ignite it a day later and let the stump smolder underground.
For some reason, now that I type it out, I think it was more of the latter (smoldering) than rotting.
Perhaps he was going to soak with kerosene?
Anyways, that's all I know in it... I ended up popping them out with my backhoe and he never did it.
Richard
   / Burning stumps #4
Dang that slowrev is a fast typest! /forums/images/graemlins/shocked.gif jumped right in front of me
/forums/images/graemlins/grin.gif
   / Burning stumps
If I remember correctly it is saltpeter that you pour into the holes to hasten decay but I've never tried it. When I burn them I have a problem with the stump's fire suffocating under it's own ashes.
   / Burning stumps #6
I bought a piece of 4' metal culvert 4' long, they use them as drywells buried and filled with rock. Set that puppy over a stump and build a good fire in it and it will cook a stump pronto and contain the fire so you won't burn the countryside. Works great.
   / Burning stumps #7
I have used "Stump-Out" in the past. You need to add kerosine, but it does work well.
Info
Gary
   / Burning stumps #8
Small walk behind stump grinders work great. Very little turf damage and they grind the stump into mulch. Then all you have to do is dig out a little of the chips and add soil, and your ready to grass over the stump....
   / Burning stumps #9
We have had good results with setting a piece of tin around the stump and spreading a few bags of charcol over the stump and set it on fire. It will usually smolder for two or three days and anything that is left is easily removed. /forums/images/graemlins/smile.gif
   / Burning stumps #10
Someone once told me copper sulfate was the stuff to pour in them.
2021 TAKEUCHI TB235-2 EXCAVATOR (A52706)
2021 TAKEUCHI...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
2019 Ford Transit Cargo Van (A51694)
2019 Ford Transit...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
