Burning Oil
/ Burning Oil #1
Dave1958
Sudbury, Ma
Sears Craftesman 917.254530
My Sears lawn tractor is burning oil badly. It's an oldie but goodie. Worsened over time, really bad now.
Oil coming out muffler.
I noticed there is oil in the carb bowl as well.
Just ordered head gasket.
How can oil get in the carb bowl? I emptied it, restarted, oil in it again immediately.
Thanks for any help.
/ Burning Oil #2
If you're getting oil out the muffler, that's more than a head gasket, it's likely worn piston rings, and maybe (likely?) valve guide seals. I'm not familiar with that engine, but completely trashed valve guide seals could allow oil back into the intake, then down into the carb bowl.
Sounds like time for a complete overhaul.
/ Burning Oil #3
Piston rings or Cylinder bore worn. Excess pressure in the crankcase from worn rings. I would imagine the engine is completely rebuildable. If you don't fix the oil burning you'll burn an exhaust valve for certain.
Good luck, Fred
2006 Volvo VNM S/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM S/A...
2024 SILVERBACK 53CH3A TRI/A CAR TRAILER (A67148)
2024 SILVERBACK...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A67148)
2019 INTERNATIONAL...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
