Burning Ask Wood -- Heavy Soot
   / Burning Ask Wood -- Heavy Soot #11
"A few fires" in October sounds like low heat, smoldering types. I've burned an awful lot of wood for many years including dry ash, green ash, and about everything else. I'd guess that when it gets colder than early October and you start cranking the BTUs faster out of your ash wood the burn patterns would change as you would have hotter fires.
I also would not be overly concerned that the inside of my firebox is dirty; a hotter fire will take care of that. When I clean my chimneys I re-burn the creosote I collect from them.
   / Burning Ask Wood -- Heavy Soot #12
I have a lot of ash on the property and end up burning more of that than birch or maple, and you can get away with burning it a bit wet. It helps to split it a little thinner and make an open cradle instead of a tighter pile to increase the exposed surface area and get it going. Unfortunately you lose some of the btu's for heat to boil off what extra moisture remains, before it can get up in temperature. If I'm stuck with wet wood, I'll start the fire dry, then try and mix green and seasoned once there's some coals to ignite everything quickly. I think you encountered a lot of smoldering while you cooked off water. Get it hotter and the soot should disappear--did you clean the chimney at the start of the year, or could you have some creosote thats fallen through the off season and disrupted your air flow? I have a little magnetic thermometer that lets me know the stack temperature, and it translates well to the fire's character--in "the zone" goes well... under that and its a smoldering PITA.
They aren't split and most are about a foot in diameter so they burn long and slow. But they have been standing dead for at least two years and are cracked at the ends of the cuts so I would assume they are sufficiently seasoned. They do get wet just sitting on the pile but they also appear dry after a day of sunny weather.
We haven't had much soot in the chimney over the years because we burn dry wood and have hot fires. There is no damper so its always wide open so to speak. I think it must be caused by the long slow fires these big logs create.
   / Burning Ask Wood -- Heavy Soot #16
It's not seasoned just because it's dead and standing for 2 years. Split it, stack it, keep it covered on top and allow air to get to it. Mix it in with actual seasoned wood and use a stack thermometer, as already suggested, to get the hottest burn. Otherwise you're drying it in the stove, and the soot is the water burning off ineffectively and inefficiently. You can't wish it dry.:confused3:
   / Burning Ask Wood -- Heavy Soot #17
I have had 2 year or longer standing dead wood ooze out water when the splitting wedge hits it. I burn most of the already dead wood on the brush pile because it is so hard on chainsaw chains.
   / Burning Ask Wood -- Heavy Soot #18
Wet wood isnt what directly causes creosote.
Creosote is caused when gasses and smoke cool off and condense on the inside of the stove and chimney.
Burning wet wood can cause this as the moisture cools things off. But so does a cool smoldering fire when you choke the fire down. You need a good hot fire to prevent creosote.
A fire stoked for overnight and choked down will form a bit of creosote, but then in the morning when you open it up and get a good hot fire rolling, you are burning it off. This time of year when you may not need a good hot fire, you simply may not be burning hot enough to prevent creosote.
   / Burning Ask Wood -- Heavy Soot #19
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
(11) 2 PLUG VALVES (A52472)
(11) 2 PLUG VALVES...
2008 Chevrolet Impala 50th Anniversary Sedan (A51694)
2008 Chevrolet...
2018 John Deere 460E Articulated Dump Truck (A52748)
2018 John Deere...
