Bumwoo hydraulic pump
/ Bumwoo hydraulic pump #1
eagle2426
2010 Bobcat CT-122
need info on a Gear driven Bumwoo pump. off bob cat ct122
M21-99L
5700045 OR 5706045 OR 5000045 OR 5006045 OR 5200045 OR 5206045 <----- SERIAL NUMBER Not sure which one it is because it is engraved on plate. Any info would be very helpful. need specs, flow rate, what pressure it produces. Thanks for your help
/ Bumwoo hydraulic pump #2
[Good luck, the bumwoo pump was a poor quality pump, low how failure rate 300-400 hours , 7.66 gpm. Bobcat is discontinuing the tractor. and the only pump they offer is $1000 which compared to other tractors is outrageous. Kioti will sell you one but you get no warranty if it goes on a Bobcat although its the same tractor MFG by Daedong. terrible customer service. The story is Kioti and Bobcat are competitors with each other so they do not want to provide any info.
QUOTE=eagle2426;4481618]need info on a Gear driven Bumwoo pump. off bob cat ct122
M21-99L
5700045 OR 5706045 OR 5000045 OR 5006045 OR 5200045 OR 5206045 <----- SERIAL NUMBER Not sure which one it is because it is engraved on plate. Any info would be very helpful. need specs, flow rate, what pressure it produces. Thanks for your help[/QUOTE]
Thank you for your input. Is there ANY other Pump mfg that would work other than Kioti??
Caterpillar D7H Series 1 and 2 Dozer Service Manuals (A63117)
Caterpillar D7H...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
HARDEE 16' TILT TOP TRAILER (A63291)
HARDEE 16' TILT...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
