Bob_Young
Veteran Member
- Joined
- Jul 5, 2002
- Messages
- 1,211
- Location
- North of the Fingerlakes - NY
- Tractor
- Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
I've read that the correct way to bulldoze with an FEL is with the bucket level and full. It's designed for this and doesn't put excessive force on the bucket cylinders. However, this hasn't been effective for me as my bucket trys to ride up over what I'm trying to push and leaves alot behind.
I've found that if I lower the bucket edge 30 to 45 degrees below level toward the dump position and then lower the bucket so that the edge is an inch or two off the ground I can bulldoze snow easily and do a cleaner job of it. Because I feel this stresses the bucket cylinders, I go slow in 1st or 2nd with hand over the joystick in case I hit something. I think I'm asking for trouble with this but it does a nice job. Been using this to push snow piles back from the edge of the drive. Back blading with the rear blade would probably be best, but this is so easy.
Wondering what you old FEL hands do in this situation. Anyone damaged their loader doing it the way I am?
Bob
L4300 with LA682 Loader
Bob
