bulldog front loader
   / bulldog front loader #1
coppertop1
d1650
Hey folks, I have a Mitsubishi tractor with a Bulldog 285 front loader on it. I had the boom cylinders rebuilt not too many hours ago and they did fine..until last week. Now the bucket leaks down fairly quickly. The bucket will pick up and hold the front of the tractor off the ground when I press the bucket down. I thought if just one cylinder was bypassing the good cylinder would still hold the empty bucket. Think maybe its an O ring in the valve body? Any ideas? Thanks
   / bulldog front loader #2
Rarely is it the valve. Typically the valve bore and its spool are fitted to such close tolerances ordinary mechanics can not measure the clearance.
It is this tight tolerance which prevents leakage.
Swap the lift arm hoses for the bucket hoses and see if the problem persists. If so then the problem is in the cylinder(s).
Disconnect and cap the hoses for one bucket cylinder so that you are observing the performance of only one cylinder.
There are more complicated but accurate double acting cylinder tests as I will post below.
Dave M7040
  • Testing double acting cylinders.pdf
Dave M7040 I really appreciate the help.
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
BUSH HOG 7007 LOT NUMBER 36 (A53084)
BUSH HOG 7007 LOT...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2006 FORD F250 SERVICE TRUCK (A53426)
2006 FORD F250...
Rogator New Leader RG1100 (A50123)
Rogator New Leader...
