Bulkhead for Grapple Hydraulics
/ Bulkhead for Grapple Hydraulics #21
Redbug said:
Wayne County Hose...A question or two, (if you don't mind)...I did not know under pressure QD's existed. How do they work? Are they more expensive than normal connectors? That means you could change out attachments without turning the tractor off and equalizing the pressure...Hmmm.
How do they work? I don't really know. I never looked into it. The male end can be up over 5,000 psi, the female end has to be zero, or close to it. Welcom to Holmbury. Look up APM series. There are other manufacturers that have them as well.
/ Bulkhead for Grapple Hydraulics #23
3RRL said:
What do those babies cost?
I see you have to fill out info to get a quote...
Any idea?
Rob, you know what they say, if you have to ask, :D
/ Bulkhead for Grapple Hydraulics #25
RedBug,
WR Long makes a pretty clean bulkhead valve kit for Kubotas. I seem to remember it about $50-$60. The bulk head plate kit includes the bulk head plate with bulk head fittings along with two sets of hydraulic quick couplings.
Third item down at Valve Kits
/ Bulkhead for Grapple Hydraulics #26
I like the custom bulkhead, I just got my LD48 grapple from Millonzi and love it, I am planning on building a similar setup but will install my 90's befor the quick couple. I will post some pics when I finish it up. The Long setup gave me the idea, but it looks bulky and vulnerable to damage. I want something more custom. Keep up the great work.
JustCountry,
Thanks for the comments - can't wait to see your set-up! Have fun
Brad
/ Bulkhead for Grapple Hydraulics #28
RFB,
Several of my friends have the bulkhead kit installed on their tractors. When I ordered mine I forgot to specify the kit. More people have them installed as not. I plan on ordering the kit in the near future and doing the install myself.
That's probably a good idea Justcountry about making the bulkhead less vulnerable to damage by welding some angle iron to the sides, etc. I did that on my WR Long grapple...where the hoses connect to the grapple itself. One of the other TBN members, (RPK to be exact), mentioned about doing it to his, and after using mine, I noticed a few limbs grazed that area when pushing debris. I did it before something got messed up. I'm glad he mentioned it because I started watching that vulnerable area closer when using the grapple.
/ Bulkhead for Grapple Hydraulics #29
3RRL said:
lol Brian, :D :D :D
So how much do you think then?
Andy, do you have any idea? You ever use them?
Rob, I have no idea. all that I know is that they are not cheap and right now that is all the info that I need to know. :eek:
/ Bulkhead for Grapple Hydraulics #30
Hey lincolnVT,
Where did you buy the actual bulkhead fittings? I didn't see that info in the post. Nice job BTW......
Bob W from Maine
/ Bulkhead for Grapple Hydraulics #32
Thanks JJ
Caterpillar 318BL Excavator (A65579)
Caterpillar 318BL...
Rear Axle For Case IH 2388 Combine (A65640)
Rear Axle For Case...
Club Car Electric Golf Cart (A66285)
Club Car Electric...
2014 John Deere 6105D (A64126)
2014 John Deere...
IRGC40 High End Mini Golf Cart (A64127)
IRGC40 High End...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
