bulk methanol ballast $1/gal
   / bulk methanol ballast $1/gal #1
schlen
wichita,ks
Couldn't find wwf less then $1.69 a gallon so I found a barrel of methanol at a fuel/oil dealer. $225 w/tax for 55 gal-- 4.09 a gal plus a free barrel. Diluted it 3-1 with tap water (25% meth) good to 0 deg. F. Ballast for $1 a gal. Fit about 33 gal in each tire of my massey 1433 15x19.5 r4's. I was surprised 1 tire and wheel empty weighed 235 pounds:eek: fluid should add 264 lbs to each tire.
I mixed it in a small barrell then pumped it in with a manual diaphram pump hooked to a tsc valve. I think i'll put some in the tc33 as well. I'm looking forward to added hillside stability when I'm bush-hogging next year, plus the r4's need all the help they can get.
After ballasting two 30hp tractors I will have spent the equivalent as if I had bought wwf for both but I should still have 25 gal. of methanol left for home-brew wwf in the trucks and to experiment making biodiesel.:D
   / bulk methanol ballast $1/gal #2
Very nice- I've got 4-5 gallons of old model airplane fuel I've been saving for when I've got a wet burn pile, maybe I can use that. Think 10% nitro would be bad for the tires, or just help me go faster? :) It's got 5% oil in some of it too.
So you pumped it though the fill valve, or slipped another line past the rim?
(INOP) 2015 FORD F-250XL SUPER DUTY TRUCK (A57192)
(INOP) 2015 FORD...
3410 (A47477)
3410 (A47477)
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
2018 Ford F-550 4x4 Stellar EC3200 1.5 Ton Crane Service Truck (A55852)
2018 Ford F-550...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
UNUSED FUTURE SGB20 20" HYD STUMP GRAB BUCKET (A57193)
UNUSED FUTURE...
