bulk methanol ballast $1/gal
   / bulk methanol ballast $1/gal #1
schlen
wichita,ks
Couldn't find wwf less then $1.69 a gallon so I found a barrel of methanol at a fuel/oil dealer. $225 w/tax for 55 gal-- 4.09 a gal plus a free barrel. Diluted it 3-1 with tap water (25% meth) good to 0 deg. F. Ballast for $1 a gal. Fit about 33 gal in each tire of my massey 1433 15x19.5 r4's. I was surprised 1 tire and wheel empty weighed 235 pounds:eek: fluid should add 264 lbs to each tire.
I mixed it in a small barrell then pumped it in with a manual diaphram pump hooked to a tsc valve. I think i'll put some in the tc33 as well. I'm looking forward to added hillside stability when I'm bush-hogging next year, plus the r4's need all the help they can get.
After ballasting two 30hp tractors I will have spent the equivalent as if I had bought wwf for both but I should still have 25 gal. of methanol left for home-brew wwf in the trucks and to experiment making biodiesel.:D
   / bulk methanol ballast $1/gal #2
Very nice- I've got 4-5 gallons of old model airplane fuel I've been saving for when I've got a wet burn pile, maybe I can use that. Think 10% nitro would be bad for the tires, or just help me go faster? :) It's got 5% oil in some of it too.
So you pumped it though the fill valve, or slipped another line past the rim?
2016 GMC Savana (A50120)
2016 GMC Savana...
2014 Volkswagen Passat TDI SE Sedan (A50324)
2014 Volkswagen...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2007 STERLING L9500 TANDEM AXLE DAY CAB (A52141)
2007 STERLING...
2014 DOONAN (CHAPARRAL) 502BBNHTTBZF 50FT CONESTOGA XP SPREAD AXLE FLATBED (A52141)
2014 DOONAN...
