5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 24,782
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
With fuel prices going through the roof, what you need is a bulk tank...
Check local papers, flea markets or the scrap yard and find a 275 gallon fuel oil tank. There are a lot of them around as homeowners are changing from fuel oil to piped gas or propane.
Truck the tank home, purchase a 12 volt or 110 volt transfer pump about $150.00 at TSC, set the tank next to your garage (it already has feet) and call your local petroleum supplier and have the tank filled. Tell them it is for "off road use". You are only taxed on fuel used for "on road purposes". Your tractor is not "on road". Since it is "off road" taxes on fuel do not apply. Remember-DON'T PUT THE FUEL IN YOUR PICKUP OR CAR AS IT IS DYED RED AND IF CAUGHT YOU WILL BE FINED FOR IT'S USE. The first time fine for misuse of red dyed diesel in an "on road" application is $5,000.00.
We have 2 bulk tanks. One is 5000 gallons at the main farm and a 275 gallon which is an old home heating oil tank at the shop which is what I use for my Kubota. It's also a lot easier to fill your tractor with a nozzle than with a 5 gallon can. /forums/images/graemlins/grin.gif
If you can't find a tank, most bulk suppliers will provide you with a skid mounted tank for purchase or lease. If you lease, you will have to use their fuel and sign a contract to that effect. Petroleum suppliers can be found in your local yellow pages.
Daryl
Forage Services L.P.
Daryl
