bulge in tire???
/ bulge in tire??? #1
NBstunter
new brunswick canada
2006 kubota L2800
is this repairable? if i need a new tire do i need 2 of them? really can not afford that right now.. is it still safe to use it? any opinions welcome... ughh..
/ bulge in tire??? #2
You've got a separation in the outer layers of tire ply.
2 ways to take care of this.
1) Replace.
2) Pop the outer bubble and cross your fingers.
/ bulge in tire??? #3
I am no tire expert, but I would think there is no way that tire would carry much load on it. I have never seen anything like that on a tractor tire. I have seen trailer and truck tires seperate like that. They were imediatly replaced. Good luck.
/ bulge in tire??? #4
new tire. had one like that it swelled up about double went about a 100 yards ,then blew.i figure i broke the belts on the inside, after running over a rock.
/ bulge in tire???
been driving it like that for a few weeks now.. i know because ive been wondering why it was suddenly rough on pavement.. i can tell the outside rubber is much much softer then the rest of the tire... im guessing that means that the outer ply and the bubble are not under the presure of the tire? think tomorrow im gonna drill a tiny hold in it and see if the tire starts leaking.. and if so just stick a plug in it for the moment till it blows. :mad:
/ bulge in tire??? #6
I've seen them more than a few times, mostly on recapped semi trailer/chassi tires.
The ones that see the road get replaced no question.
Yard trucks and yard chassis just get the bubble popped.
Some leak, some de-ply even more and some nothing happens at all.
It's a tractor tire, pop the bubble and hope for the best.
/ bulge in tire??? #7
There is a tire repair shop a few miles up the road from me. They repair tires that cost tens of thousand of dollars. Well maybe not that much certainly not cheap tires. You know the big ones that are 8-10 feet tall. Smaller tires also. Anyhow a shop that does those kind of repairs might have a solution. those big expensive tires have patch after patch on them where they cut out the sidewall and vulcanize the patch in. I had atractor tire fixed once. Worked great. I left that farm and came back a few years later to do something. Some idiot put 60 psi in the tire that was supposed to have less than 20 and tore the patch.
/ bulge in tire??? #8
Take it to a tire shop where they can have a good look inside to see if there are no breaks that will pinch a tube. If all looks good in that respect have it tubed.
/ bulge in tire??? #10
that is good i have other tires with boots in them that have lasted a long time.
/ bulge in tire??? #11
As long as you don't exceed 90mph you should be all right. I wouldn't even pop it.
/ bulge in tire???
went to get it repaired at a tire shop.. they said it was unrepairable and said they have one in stock [pretty sure it was repairable they just make more off selling me a new one :mad:] i poked a hold in the bubble and it was under the pressure of the tire as it was leaking everywhere so just poping it wasnt gonna fix it.. $600 out the crapper :mad::mad::mad:
/ bulge in tire??? #13
Since the pressure in the bubble comes from inside the tire what made you think piercing the bubble would help????? Why wouldn't a tube & boot have kept it going? MikeD74T
/ bulge in tire??? #14
I agree, a tube and boot would have fixed it for about $75 or so. Too late now. I would also consider changing the other rear. I know its not 100% necessary but having matching tires and tread depth is the best way to go.
Chris
2015 John Deere 3046R Compact Utility Tractor (A63116)
2015 John Deere...
2011 CAT 140M2 Motor Grader (A64047)
2011 CAT 140M2...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
Informational Lot - Financing (A63688)
Informational Lot...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
2007 Ford F-250 Crew Cab Pickup Truck (A61573)
2007 Ford F-250...
