Built my own quick attach FEL, forks, sprayer
   / Built my own quick attach FEL, forks, sprayer #1
scarlo101
Ontario, Canada
Kubota BX 1850, NH TN75
Hi all. Just wanted to show you all my latest bullds. I am now working on a rear ballast weight. AutoCad was my best helper for the FEL.
As you will notice in the pics I also built my own snowblade for the front. I built it so that the rear 3PTH control raises the blade up and down. It works very well, but since then found a used bota blade. My home made 48" blade is now for sale. Click on link below for all the pics.
   / Built my own quick attach FEL, forks, sprayer #2
Awesome! Wish I had an iron worker, torches, wire feed, bigger garage to work in, etc... ;)
Steve
   / Built my own quick attach FEL, forks, sprayer #3
Awesome work... that loader looks better than production units :D
   / Built my own quick attach FEL, forks, sprayer #4
Outstanding work! Looks better than a factory unit. It must give you great satisfaction to get such good usefulness from something you made yourself.
Thanks for sharing.
   / Built my own quick attach FEL, forks, sprayer #6
Exceptional execution of design and fabrication. A very impressive gallery of projects. Well done!
I agree AutoCad is wonderful but for me when designing complex moving parts nothing beats a mock-up with lightweight easy cut materials. Even cardboard cutouts with push pins at pivot points will enlighten me of geometry I missed at the drawing stage.
   / Built my own quick attach FEL, forks, sprayer #7
Nice quick plate. Bucket, forks what others will you make for it?
   / Built my own quick attach FEL, forks, sprayer #8
Great work. But wheres your ROPS?
Thank you all for your comments.
No I did not use my ROPS for the FEL. I removed it because I was hitting low hanging tree branches with it and in one instance it actually lifted the front wheels off the ground while mowing. I have a level ground so I feel I am OK without it.
I am still trying to complete my ballast weight for the back. I am triyng to design a nice compact system. Would also like to make a lawn roller someday as the one in the pics is the neighbors and is a little lightweight.
My homemade snowblade has been sold and yes the ironworker is an outstanding piece of equipment. Reddirt I also used a cardboard cutout to figure out my bucket dump angle.
The only other project I am working on is still secretive as I am working on getting a patent on it. It has nothing to do with tractors or equipment, but I think it is something many users on this forum could use.
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2018 KENWORTH T800 (A53843)
2018 KENWORTH T800...
2025 CFG Industrial H15R (A50123)
2025 CFG...
Adams Tender / Magnolia Trailer (A53473)
Adams Tender /...
2018 Ford F-250 4x4 Crew Cab Gooseneck Flatbed Truck (A51691)
2018 Ford F-250...
