Built a Rock Sling
   / Built a Rock Sling #1
DIYGuy
Central Massachusetts
Jinma 224
Well,
Another weekend of moving rocks. 20 down, about 300 to go. I don't have an FEL, and although I could use one, I don't have the space. I'd have to take it off every time I mowed...
So I designed and built the RockSling(R).
Link to RockSling
   / Built a Rock Sling #2
I've found that my tire chains work well for pulling big rocks out of holes too. Just attach the tire chain around the rock and pull it out with anonther chain.
Tim
   / Built a Rock Sling #4
did you name it little David ? /forums/images/graemlins/smile.gif
Looks neat.
I have a couple big nylon webbing slings that are very handy for lifting and wrestling things around.
   / Built a Rock Sling #5
Great idea.......I think even with a FEL the Rock Sling would be easier to use. I am guessing most of your rocks are about the same size. If not I saw the adjustment holes in the base.
   / Built a Rock Sling #6
DIYGUY:
nice sling... I still haven't tried MOVING my bolders out of the bottom land yet:) I will probably move them using somethign similar... I have soem bigger than the ones you have in the sling on the other forum (china one I think).
Mark M /forums/images/graemlins/smile.gif
EDIT IN:
was that one you built you're self? I was thinking of buying an inexpensive 3pt pallet fork carry all thing and adding holes and some D rings . they can be had for CHEAP usually... just thought I'd mention that for those who can't weld /forums/images/graemlins/wink.gif
Mark
Took about 8 hours from start to finish. Would have been less time if the wire spool on the MIG didn't get all discombobulated.
I got the idea watching a forklift move large stacks of product around at a warehouse.
I needed a way to lift and set rocks in tight quarters. A traditional sling sets the rock on the sling, so now you have to get the sling out. A pallett mover has to be able to slide under the rock, not possible in my application. Here all you need is the sides exposed such that the the legs can be drawn in narrower than the rock.
Follow-up. Here's a rock that required 250 lbs of additional front wieght to lift.
I will need to beef up the leg attachments to continue to lift things this big.
   / Built a Rock Sling #9
</font><font color="blue" class="small">( Follow-up. Here's a rock that required 250 lbs of additional front wieght to lift.
)</font>
/forums/images/graemlins/shocked.gif That one weighs as much as the tractor, huh? No better testament to your engineering though. /forums/images/graemlins/grin.gif
Chris
   / Built a Rock Sling #10
As you approach the rock, does the articulating lower arms cause any trouble with sticking into the ground?
2007 WESTERN STAR 4900 (A52472)
2007 WESTERN STAR...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52748)
2024 Ford F-350...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
