Building ToothBar need advice ..
   / Building ToothBar need advice .. #1
deerhunterf350
St. Louis, Mo
New Holland TC55DA
I have looked at the TB that JohnF_ASI built and going to use his idea.
Question is would 1/4" x 3" x 72" bar be heavy enough for use in the Bucket to weld Bar Stock to , or should I use 3/8" x 3" x 72" .
72" wide HD bucket on a TC55 , which from what I have been reading and from looking at the Specs that is a Strong Loader.
   / Building ToothBar need advice .. #2
I would not use anything less than 3/8" x 3". In fact I would probably go up to 1/2" x 3". You want strength here without any twisting or bending. Thicker steel is the way to go.
   / Building ToothBar need advice .. #3
Less than 3/8" x 3" is increasing the risk of big warp when you weld the teeth on..
Going 1/2" might start to introduce the necessity to pre-heat before welding.
If your fit up tolerances are pretty tight, the 'pinching' effect of the teeth will help in minimising twist.
I'm pleased that you liked the design enough to use it..
   / Building ToothBar need advice .. #4
I suggest 1/2" stock, particularily with that 72" bucket.
I used 1/2 on my 48" and would have preferred 3/8 but for sure on a 72" use the 1/2 stock.
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
2001 NEWMAR 45FT TANDEM RV WITH 2 SLIDE OUTS (A51222)
2001 NEWMAR 45FT...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
