Building ring chains
   / Building ring chains #1
tessiers
Platinum Member
Central Maine
05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
I would like to build a set of ring chains for my tractor. I saw in a recent thread a set a guy made with 3/8" round bar. I have acess to miles of rebar drops. I wonder how some #4 (1/2") rebar would be for some rings? They would be already studded. Thinking maybe a 5" dia ring for 11.2x38 tires. I already have a lot of 1/4" welded link chain, do you think it would be heavy enough for the side chains, its for an International H.
   / Building ring chains #2
There "might" be some stretching,but I made my side chains a bit long and can adjust them by just moving a 1/4 X 20 bolt to the next link. I really don't see a problem though. Think about it....a five inch ring being pulled at four equal points around it is really gonna take a lot of power.....and TRACTION!! Plus, the treads on the tire tend to hold the chain in place. I know this every year when I try to put them on!
   / Building ring chains #3
#4 would be a lot stronger then my 3/8 round too. If in doubt....weld a bar across them...like the first cut on a pizza.
   / Building ring chains #4
Rebar might be good due to it's designed rough surface, but man it would be alot of bending and welding. Rebar is pretty hard I think, harder than avg bar stock?
Rebar? got me thinking, you could come up with all kinds of ideas, Like a solid link across the tire bent to the shape of the tread and rings on the ends for side chains to thread through.
JB.
   / Building ring chains #5
I'm not sure 1/2 inch stock would handle the strain. Most ring chains I've seen use at least 3/4 inch stock for the rings, if not heavier. I went with studded ice chains, primarily because I don't like the way ring chains grab and then slip.
They're also play **** with paved surfaces, at least the kind with teeth do.
Chilly
   / Building ring chains #6
I'd worry about rebar failing and then having a piece that may puncture the tire. A chain that fails will likely not have danger.
   / Building ring chains #7
I'm quite willing to bet the clutch would burn up before an H would spin the rebar.
I don't believe that old H could break a #4 bar, so you must be questioning my welding. LOL My father does a little recreational blacksmithing so He is going to make the rings for me in his forge. He says let them cool slow and they will work fine.
   / Building ring chains #9
In time, they do wear. :)
Not questioning anyone's welding at all. :D
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
toro turf sweeper (A50324)
toro turf sweeper...
(1) 24' CORRAL PANELS W/ (1) 8' GATE (A51243)
(1) 24' CORRAL...
1049 (A50459)
1049 (A50459)
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
