Building Lake Corona
/ Building Lake Corona #1,341
How much rain did you get in your rain gauge to get six inches in the pond? For my two ponds, the small one will rise six inches with one inch or rain when the ground is already wet, but the big pond will only rise two inches from that same amount of rain.
2-1/8"
2 more inches of rain today and came down fast. Gained 9-1/2" on this one. What Dodge Man called my blue shop vacs (fish structure) is almost covered now. 4 ft to go.
/ Building Lake Corona #1,346
We're expecting storms tonight and Saturday night. Hopefully it will head your way too!!
Things have dried up here so no more water progress to report. I did finally get around to spreading my pile of top soil over the hillside that I moved the clay from. Going to seed and hopefully get some cover established to prevent erosion as much as possible. Water loss is still looking good. Averaging 1/8" per day on these hot 90 degree + days. That loss is on the low end of what calcs are showing for expected evaporation loss.
/ Building Lake Corona #1,348
You probably have some benefit from being surrounded by trees that reduce wind speed across the pond, slowing evaporation.
Congratulations on the low water losses!
I hope that you get more rain.
All the best, Peter
/ Building Lake Corona #1,350
Woo-Hoo!
Guessing it's still a little early for 10# Bass??!!
/ Building Lake Corona #1,351
I forget what you're plan for stocking it is. You can put minnows and bluegill in there now. Then when it's full and the water clears up and the plant life starts growing, you can put in your predator fish. It's too small of a pond for two predators, so it has to be a type of bass or a type of catfish. Depends on what you want to fish for. Or you can just have pan fish as your predator. Bluegill are what I have, but a lot of people really like to catch and eat Crappie
Woo-Hoo!
Yeah probably. Hopefully I can stock it next spring, or at least start with fingerlings. Water at the moment is 3 ft tapering to 8ft as it reaches the dam.
Would like to do bluegill and bass.
Started working a bit yesterday piling some rocks along the waters edge in a few places for some additions fish structure. These all came from digging out the pond bottom on the redo work. Should put these at about 4 ft of depth when full.
Our drought here continues. A drought declaration for the state was issued last month. Since July 31st we have had a total of 3/4" of rain. Most of that coming last week. Despite that I've been able to get some grass established on the hillside I pulled the clay from. Saving and spreading the top soil helped a bunch.
I've also spread some gravel in the 2 to 4 foot range of some of the banks for spawn beds. Today I laid a piece of 8" drain tile I've had laying around as a 2nd overflow and cut a channel for it so if it's ever used it will flow around and not down the dam. I'll be surprised if it's ever used much if at all.
Took a measurement today I have exactly 4 ft to go for the pond to be full. That means it's about 9 ft at the dam and anywhere from 3ft to 5ft around the rest of the pond. I'm only down about 5" from end of July when the rain stopped. Will update next spring/summer on any additional progress.
/ Building Lake Corona #1,360
You've done well to be down only 5 inches over three relatively hot and dry months!
Very encouraging!
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A65643)
2016 PETERBILT 567...
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
Carpet Cutting Table (A65579)
Carpet Cutting...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
