Building Lake Corona
   / Building Lake Corona #451
We didn't get anything last night. Chances diminishing all day. Hope you are as lucky.
   / Building Lake Corona #453
I guess we are fortunate around here in the PNW not to get crazy rains in the summer time to mess with projects like this!
Water is down several feet as of this morning and no rain in the forcast until Sunday so looks like I'm in the clear. Should be able to get out tomorrow and start clearing the trees I've dropped. I'll probably focus solely on tree removal around the entire pond basin before going back to moving dirt.
2020-07-22_08-13-51
2020-07-22_08-13-05
   / Building Lake Corona #455
Yep, I would too.
Stuck #3. Was moving too quick and dropped a track into a hole next to a tree I was digging out. In the process I threw the right track that was in the hole. I decided this time to record a video of using a chain and bucket to drag the CTL out to level ground.
   / Building Lake Corona #457
Never thought of using the bucket to curl your way out of a hole. That's a lot of in and out of the machine for every foot, but it definitely worked!!!
   / Building Lake Corona #458
I do that more times than I like to admit, hoping every time that my bucket hook weld will hold. With a tractor you often are in a hole, so just need to do it once.
   / Building Lake Corona #459
It probably wouldn’t have worked with 1 track off but I’ve used my tractor with the cruise control on to assist in pulling another machine when I was by myself. I had a CTL buried deep in a stump hole and got it out that way. I’ve also pulled my bucket truck out with it in gear. I couldn’t pull it dead weight so I put it in gear, pulled it almost out, then took it out of gear and pulled it the rest of the way.
It probably wouldn稚 have worked with 1 track off
The right track in the hole was off. Hydraulics at least on this machine are strong enough to drag it with or without tracks turning.
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2020 DRAGON ESP...
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
