Building Crossing Over Seasonal Runoff/Stream
   / Building Crossing Over Seasonal Runoff/Stream #1
Engine66
Orange County, CA & Vermont
JD 2305 & 4720/400cx/BH448
I have a seasonal stream following snow melt, rains, etc. that I would like to cross over. Unfortunately, crossing it is only possible during a deep freeze or the driest time of summer when it's mushy. Otherwise it's plain wet and muddy. The site in mind is about 10' wide and slight depression where water accumulates. Any of you have good ideas for building a crossing? I was thinking of building up each side a bit with the BH, put down corrugated drainpipe, and cover wet area and pipe with large sized crushed rock. Any ideas, suggestions, problems, etc. you can share? Thanks for the help, ideas.
   / Building Crossing Over Seasonal Runoff/Stream #2
I have just about the same problem based on your dimensions mine totally dries in the summer, I first dug it out a little and put some gravel in, but mine is pretty flat so the water does sit there and it still got muddy.
I think you answered your own question, just a basic culvert. I didn't want to do it at first but I think now I will, mine is only draining the run off from a few acres, but when it rains hard, especially in the winter/spring it does flow pretty good, I was thinking about laying 3-4 pcs of 6" pipe down side by side and covering over it with gravel, this way I wouldn't have a big mound to drive over if a larger in diameter pipe was used.
If yours has alot of standing/ponding water you will want to fill in under the pipe a little so they are not completely submerged, maybe a quarter submerged is OK, that way they wont get completely filled with sediment, it will cause the water to pond up on the up hill side but that shouldn't be a problem.
A couple of pics showing an extreme event, fixed much of this by cutting a swale with the box blade
   / Building Crossing Over Seasonal Runoff/Stream #3
Wow! click-able thumbs and I didn't even try to do that, something new???
JB...thanks...great pics. Your boxblade did a great job with your soil...wish mine was that way...I have too many rocks in soil. I'll try to post some of my site. Anyone have any pics of their similar projects?
Bigballer...nice job on your project...very, very similar to what I am going to do. Now that it's done and you have had some time to re-examine it's operation...do you find any sediment building up on the inlet side? Also, and maybe Eddie can answer this, would a low-head dam, or dug out section ahead of inlet side allow sediment to sink and deposit before getting to the pipe or is your rock arrangemet sufficient? I like the cement bag idea...excellent, economical, easy, expandable...list goes on...very nice. Thanks for the valuable input and pics!!!
   / Building Crossing Over Seasonal Runoff/Stream #7
the rock arrangement in front of the inlet stops alot of debris and probably allows some of the sediment to drop out because the water slows down there before spilling over towards the inlet. overall it's held up really well and i don't really see anything at this point that needs attention except for the floor of the ditch. i might add some small rocks there i have been gathering around the property. i am also toying with the idea of adding a few more sections of pipe to it and covering up so i can extend my usable area around the back of the barn..
good luck!
UNUSED Black Outdoor Patio Fabric Screen (A53117)
UNUSED Black...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
Adams 6Ton Hydraulic Lime Spreader (A53473)
Adams 6Ton...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2016 KENWORTH T370 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T370...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
