Building a Tractor Shed for My Kubota
   / Building a Tractor Shed for My Kubota #11
Nice shed build. I have watched several of your videos and just finished the 3 part on the ballast box.
I知 doing the exact same thing.
I to have a slope down into the pad. Did you do anything special for water runoff like a French drain or stem wall in the outboard end?
Edit, after watching the video I see the details for drainage with the drain system.
Lenny
👍 Yes and the French drain has worked well.
   / Building a Tractor Shed for My Kubota #13
Looks pretty good. How did you flash the roof to the existing building?
I've quit using treated 4x4's for anything taller then a deck railing, and even then it's iffy. I've found that it's too big of a gamble on which ones will remain strait and how many will bend, bow or twist on you. I went up to 4x6's for a project and had one of them bow on me so badly that I had to replace it in only 3 months. Now I only use 6x6's so I never have to do it again. They also allow me to notch for my beams and not rely on bolts to support the load.
I cover that in the video, but basically it’s a piece of flashing made for this application, ordered with the panels and sealed to the siding with flashing goo.
I hear you on the 4x4s. These have been fine so far. I used 6x6s on my front and back porches and only one developed a very slight bow.
   / Building a Tractor Shed for My Kubota #15
I dont watch videos, so I was just curious since the pictures didnt show it.
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2012 Nissan Altima Sedan (A55758)
2012 Nissan Altima...
John Deere 6115D (A53314)
John Deere 6115D...
CAT D6C Dozer (A47477)
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
MMS Walk Behind Trowel (A53316)
MMS Walk Behind...
