Building a stick frame house in the woods in 90 days
   / Building a stick frame house in the woods in 90 days #571
Don't vent the attic, codes allow you to spray foam the sheathing and walls, about 1 inch thick, will seal the house against air infiltration, venting was invented for fiberglass insulation which needed to have a way of removing water vapor removed because it lowered the r value. Use Celulose or foam or mineral fiber as the insulation in addition to the 1 inch foam. Don't fall for the fiberglass hype, r-19 at 70 deg. equals r-6 at 0 deg., not true with other insulations.
   / Building a stick frame house in the woods in 90 days #572
Pete,
There will very likely be more rain event days this spring before the fireplace is finished and all sealed permanently.
I know your sub-floor material is touted to be submarine skin worthy but I wouldn't chance it. There are bound to be cut edge panels in this area and the sealer will be gone, so edge swelling could occur.
With your tarps or some scraps from the build, it would be very easy to keep 99% of any water off the roof from entering the flu box till the project is done. That area will need to be dry before insulation is put in and plasterboard put on the wall.
Considering the width of the flu box and its position at the bottom edge of the roof it might be wise to build a little ridge on the up side to divert the water off to the sides of the flu box. I didn't see that detailed on your drawings, but that doesn't mean that they were not going to do it.
The ridge vent material we used is called "Quarrix" in case you want to compare it to the many others that are available. They have a web site.
Ron
   / Building a stick frame house in the woods in 90 days #573
Pete,
Ron
Pete and Ron, the little ridge for the chimney is called a "cricket". The carpenters I'm sure will add that when they get around to the chimney but Ron is right for now cover it up with something to help keep the water out. Regarding the floor being flooded you can also drill 1/4"-3/8" holes in the areas where the water is puddled to let it drip into the basement. Helps dry it out somewhat.
Day 57
I arrived just as the roofing material was being dropped off.
It looks to include all the items being discussed
Closeup of main shingles
Closeup of what I assume to be ridge shingles
Misc shots around the house
Ron they did cap the chimney today
On the inside, plumbers and HVAC crews started today
   / Building a stick frame house in the woods in 90 days #575
Cool to see the plumbing and HVAC rough-ins starting.
Ron, the sub-floor is impregnated through with epoxy or similar, so you don't have to worry about edges, cuts, etc. It's darn tough stuff. Ours was out in the weather for over two months, including one hurricane, with nary an issue.
   / Building a stick frame house in the woods in 90 days #576
Pete,
I think you will find that the Supreme AR shingles are just old fashioned 3 tab shingles. They are used with the tabs pointing up as starter shingles and with the tabs pointing in along the edges at the ends of the roof. Since your 3D no tab shingles have a second layer to give the bumps they can't be used as starter strips.
Lookin good! A contractor that takes time to have a daily clean up, like yours appears too, gets extra points.
Ron
   / Building a stick frame house in the woods in 90 days #577
Not disagreeing with you, but I would love to read more about this. We have to re-roof a 50's modern home this year and are trying to work through vaulted ceiling with no insulation and a small crawl space in the other part of the house.
   / Building a stick frame house in the woods in 90 days #578
Pete:
Two other roof design features I like on this house; 1, the roof pitch is not overly steep and is proportional to the house; 2, I like the distance you extended the gable ends and the soffits as it gives a better appearance instead of being cheap to save on some materials. There are a lot of houses in my area that have ridiculous roof pitches where the roof mass overwhelms the house.
   / Building a stick frame house in the woods in 90 days #579
For cathedral ceilings in existing construction look at Injection Foam Insulation by Applegate Insulation® (Manufacturer) | Injection Wall Insulation | Foam-In-Place Insulation, or www.tripolymer.com for injected foam, although Applegate will do ceilings and tripolymer contractors balk. If you contact Applegate you will probably be talking with Owner (an Applegate).
For explanation of Energy issues in house construction look at Home | EnergywiseEnergywise | Guaranteed Energy Saving Building Solutions, with stick framing they point out chalking bottom plates, sealant at floor to drywall gap and at least 1 inch foam spray, open or closed cell to seal house.
Applegate also produces a spray foam and has Cellulose insulation.
the 1 inch spray is normally called the $2000 option for new construction, as that is usually the cost.
   / Building a stick frame house in the woods in 90 days #580
Woodlandfarms,
For your own enlightenment you might also look at:
Passive ventilation | NRCA National Roofing Contractors Association
http://www.cbs.state.or.us/bcd/programs/energy/energy_publications/ResPub_14.pdf
With New Code Changes Coming, Review of Ridge Vent Basics Is In Order | 2011-02-04 | Roofing Contractor
Also look at the requirements of the roofing manufacturers.
A 1 perm moisture barrier can be obtained in a number of ways.
Heat entrapment above the ceiling and cooking of shingles before their time is what we were all discussing yesterday, not moisture barriers.
As often said, don't believe anything you read on chat forums, always verify it for your own projects in your own area.
I am not a licensed professional architect nor a building contractor.
Ron
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
Brent 420 Grain Cart (A56435)
Brent 420 Grain...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
2016 Chevrolet Tahoe (A55973)
2016 Chevrolet...
