Building a stick frame house in the woods in 90 days
   / Building a stick frame house in the woods in 90 days #2,281
Wow. Thanks for all of your replies. Seems like the consensus is that I need to add sophit vents. I just did a temperature check using my hand held infrared thermometer. The readings are as follows:
In attic: 134 degrees
In house: 79 degrees
Outside: 99 degrees
Note that these temp readings are most likely higher than reality but I wanted to use the same device to measure all of them. As such, the relative scale should be accurate. My ductwork is fully insulated with no leaks but it has to run through the +130 degree attic. I am thinking that if I can get the attic temp down by 10-20 degrees somehow, I would save a bunch of $$$. Are sophit vents the best way to start and then gable fans later or???
-Stu
   / Building a stick frame house in the woods in 90 days #2,282
Add soffit vents and block off the gable vents, they will disrupt the natural airflow, from soffit to the ridge vents. There will he no need for the attic fan.
I reroofed my rental last winter and installed ridge vent, I had a roof fan, I left it in because it was only 6 months old. I covered all the other roof vents holes. The fan has only run a few times this season, it ran all afternoon and into the night last season. I did already have soffit vents.
When I was roofing at 30 to 45 degrees, the amount of heat that came out of the ridge vents was amazing. It was a noticeable air flow.
The ac has run much less and the renter turns it off , on days with lower humidity.
Dave
   / Building a stick frame house in the woods in 90 days #2,283
Dave
   / Building a stick frame house in the woods in 90 days #2,284
Stu,
The soffit vents will also be beneficial to your roofing system in the winter by helping eliminate frost and moisture damage to the inside of your roof sheathing. A lot of the newer roofing with the acclaimed 30-50 year life spans are very specific about proper ventilation and air flow under the roof.
As far as your statement, " I am thinking that if I can get the attic temp down by 10-20 degrees somehow, I would save a bunch of $$$"
You can conjecture that you will, but there are really too many variables in the weather from year to year and variables in household activity to prove it.
Do some readings with your IR thermometer while we are in this heat wave around your doors, windows, and outside wall electric outlets,
as well as a reading of the room your thermostat is in at ceiling and floor levels. If you want to save some $$$ on your AC bill seal the windows, doors, and outlets from outside air intrusion and close the blinds/drapes over windows/doors during the daytime during a heat spell.
Clean any leaves or debris from your outside unit and clean/replace the filter often on the inside air handler. Since your unit is in the ceiling the return duct probably has a filter above the grid.
Those of us who spend a lot of time outdoors really don't like it too cold in the house. What we appreciate is the low humidity for comfortable sleeping at night. We run our thermostat at 77 deg. with the variable speed air handler fan constantly on; which is plenty cold for us.
You have a consensus of TBN opinions so now it is time for you to take action, and for me to head out to mow another 10 acres in this 94 deg heat.
Ron
   / Building a stick frame house in the woods in 90 days #2,285
Thanks Dr. Dave and Ron.
Just to clarify, my unit is in a utility closet in my laundry room. Only my ductwork is in the attic, thank goodness. Ron you may remembering one of old posts where I said I used to have an oil furnace in the attic that worked fine except for when it really cold outside (i.e., when you really need it).
On the subject of sophit vents, consider me a total idiot. How are those typically retrofitted to a house that does not have them? My spophits plywood wrapped with vinyl. Obviously, a person would need to cut through both and shift the attic insulation to make it work. Would we be talking about removing the vinyl part, cutting holes and then replacing the vinyl with something vented or is there a more elaborate or better solution?
-Stu
   / Building a stick frame house in the woods in 90 days #2,286
-Stu
I added them to a house once. I thought it would be a dreadful task. It turned out to be fairly easy they way I did it. I went to HD and found white aluminum vents. They were approximately 6 X 12. They had a integrated nylon mesh screen. Every few feet, I marked an opening a bit smaller than the screen. I used a speed bore bit on 2 corners and cut the opening with a sawsall. It really went fast. With an opening that large, it was fairly easy to reach up and push the insulation back. I used screws to attach the screens to the existing wood. In my case, the sophit was tongue and groove pine. I can't imagine that plywood would offer any more resistance. The finished product looked nice. I paid attention to the way I faced the louvers so that the opening was against the house. They really just disappeared into the sea of white that was already there. Also, I did not stress about hitting a rafter.
In that house, I did not have a ridge vent and was installing a forced fan near the peak. The fan had a rated intake area in square inches. I added attempted to install about 150% of the requested area since I knew I would lose some flow depending on how close I cut the openings and how well I moved the insulation. I your case, if you find a vent that you are willing to look at, I would buy a stack and start installing. Every one that you install will improve the situation. Sorry, no pictures, this was almost 20 years ago....
Lee
   / Building a stick frame house in the woods in 90 days #2,287
If it already has vinyl, another way to do it would be to pop off the existing vinyl, and make 2 parallel rips down the length of the plywood, maybe 2 or 3" apart, then pry out the middle piece. Use the opening to push back the insulation. Then replace the vinyl using the perforated version. I could see color match being an issue. I also don't know if you'd have to do the whole length or could get away with doing about half or a third of area, and cutting larger openings in the ply.
When my house was reroofed last, they just used round "pop in" vents pushed into holesaw cutouts, but I'm thinking of changing them out for something else, as they used the smallest (cheapest) ones they could find. They make a continuous strip vent that screws into a 2" or maybe 1-1/2" slot, down the length of the soffit, but since you already have vinyl I suspect that would be much easier to change out, once you have some sort of opening behind it in the ply.
   / Building a stick frame house in the woods in 90 days #2,288
-Stu
Stu,
I'm back already. I was getting a low diesel light on the tractor so that's my excuse. Headed back to the barn and put in 20 some gallon,
greased the mower, and headed for the shower. They say it feels like over 100 here so the field can wait till evening or even tomorrow:)
Nelson 109 is telling you how to do it. Go shopping to see what grids with screen backing are available. Get big ones that will fit your soffit depth and between the ceiling joist/trusses. The plywood soffit material was usually recessed up an inch or so depending on how wide the board is behind your spouting. There may be a gap between the plywood surface and the back of the added vinyl but that's not a problem. Just buy a grid and install it somewhere easy to see what is going on. You might have to buy longer screws. Just snug the grid up to the vinyl so it doesn't depress it. You could make a template out of a piece of scrap that goes back against the siding so you don't have to keep measuring for every grid.
We don't know the pitch of your roof, the color, or if it is in the concrete jungle or suburbs.
It would be interesting to have Peter do similar temperature readings above his mom's ceiling as a comparison in her rural environment. The way he likes data readouts he may even already have a remote sensor installed in her attic space. He does have a hatch, for sure, where he could lay a thermometer and close the hatch a few minutes before reading a thermometer.
Ron
   / Building a stick frame house in the woods in 90 days #2,289
Thanks, Ron. I think my roof pitch is 12+/-6. I have attached an architectural drawing that they used when building the addition for further clarification. Basically, the goal was to match the ridge height to the original house.
-Stu
Stu,
Your house would be a good, above ceiling, temperature comparison with Peter's moms house.
You have a dark roof, some trees around the perimeter, and some suburb space with grass.
The little gable vents are too small and too high to do much good.
With your house front facing primarily north the heat gain through the windows should not be significant since it appears
you do use indoor shades
Soffit vents will be your best way to go IMO.
See my PM.
Ron
   / Building a stick frame house in the woods in 90 days #2,290
Thanks for keeping me honest, Ron. I followed your advice as per the PM.
I upgraded all of the windows and doors to the latest (at the time, about 10 years ago) most energy efficient that I could find. However the old part of the house still has little to no wall insulation for the most part. As you probably noted, my house does not have a basement but has a crawl space. It is a conditioned space meaning that it has insulation on the walls and several ducts for heating and cooling (no returns, however). The biggest advantage for that I have seen is in heating as it did dramatically drop the rate that my propane furnace runs. However, cooling is not so good. I guess I will have to give my contractor a call and give him a little bit of sh** for not doing this in the first place.
Just so we are all on the same page, I should comission him to create sophit vents and block off the gable vents, right?
-Stu
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
AGT Industrial ATK-B1000 2 Post Car Lift (A57149)
AGT Industrial...
New/Unused 200lbs Cast Iron Anvil (A57454)
New/Unused 200lbs...
Giyi Excavator 44" Rake (A57149)
Giyi Excavator 44"...
2002 Lexus SC430 (A57148)
2002 Lexus SC430...
2004 Kubota R520 S (A57148)
2004 Kubota R520 S...
