Building a stick frame house in the woods in 90 days
   / Building a stick frame house in the woods in 90 days #2,161
you are putting WAY to much faith in the local municipal inspector.
It would take them several hours per dwelling to do a proper inspection, and you're lucky if they are on site for 15-30 min.
We just finished building here, and I was amazed at the little things the inspectors picked up. They aren't comprehensive, but they do look at the little details quite a bit.
   / Building a stick frame house in the woods in 90 days #2,163
Peter:
With the strong threat of nasty storms this afternoon, have you tested your Mom's new generator to make sure it will fire up and transfer power properly? Last I heard you still have to manually start your's because of fuel delivery issues. Hopefully, you have fixed that now.
-Stu
   / Building a stick frame house in the woods in 90 days #2,164
Peter:
-Stu
Stu,
On 5-30 Peter said, "Moving outside, the propane was connected today and the generator is now online. I'll get the painter to paint the iron pipes to match the siding color."
I would think this means he tested it, but not sure?
Ron
   / Building a stick frame house in the woods in 90 days #2,165
Yeah, I saw that Ron. As we both know, there is nothing like a real world test, however. That is what I meant.
-Stu
   / Building a stick frame house in the woods in 90 days #2,166
Peter,
I've been thinking about your fridge issue and the mess and expense to cut the closet wall at an angle so the right door will open far enough for the drawers to come out. The curved out profile of the doors complicates the clearance further.
You may have already tried this suggestion and been turned down by your mom.
Looking at your posted pictures, have you tried pulling the fridge forward enough so everything has clearance?
That would further add some more air circulation space behind the fridge. It looks air starved and may run excessively
the way it is now.
A couple pictures for consideration.
# 1 is as you showed it installed.
#2 is with the unit pulled forward a few inches.
Ron
   / Building a stick frame house in the woods in 90 days #2,167
Neat trick Ron. :laughing: As I "drag and drop" each pic onto my 2nd monitor, I can watch the fridge "move".
Actually, the person in that one image is my aunt, not my mother. ;) I did see it before posting and let it slide. No biggie. They have actually been following this thread from abroad, and so has mom.
As far as the fridge, we did try pulling the fridge out far enough to where the door would open all the way, but it meant pulling it about 3" past the corner, which really compromised the floor space and ingress to the kitchen. The builder put a protective clear rubber bumper on the corner of the wall to keep from damaging the fridge door when opening it. The bottom drawer does pull out all the way (it goes below the lowest pocket in the door), as do other drawers on the right side. So for now, we're going to leave it like this and decide later if we want to go through the trouble of cutting out a 45 in the corner. For now, mom wants to just get fully settled in and now have workers in the house every day.
As for the railing, I do believe there are screws in addition to nails holding them to the posts, I'll double check when I get a chance.
The speaker grilles can be painted, in fact Polk includes specific instructions on how to do it. As Stu pointed out, the paint has to be sprayed on. After the 1st coat, the grill has to be turned 90 degrees and then the 2nd coat applied. This is to prevent the small holes from being clogged. Not sure we'll bother. The while matches the white in the picture frames nicely as it is.
Yes, all the speaker wire was run ahead of time, although with the large openings for the in-wall speakers, it would have been relatively easy to snake them up from below after the fact. DirecTV was installed yesterday and is working great. Mom got the Genie HD DVR, and it is great. I showed her how she could pause live TV and automatically record TV series shows, and setup favorite channel lists, etc. She was blown away. I had to cut down a cluster of 3 poplar trees to get a clear signal. One was leaning towards the house, so it was probably good to get it down anyway.
As for Internet, that is scheduled for tomorrow, and will be Satellite based (Exceed), as that is unfortunately the only option presently. Verizon were not willing to sell me a dry loop between my house and mom's, and other wireless options failed to get decent signals.
There have already been a few brief power outages and the generator comes online and transfers powers within 10 seconds. It starts within 3 seconds of loosing utility power. The generator I'm having issues with is the one at my house (the Generac).
The rock on the chimney is done, as are the front walls. I'll take some pics this afternoon of those, as well as the DirecTV dish install on the chimney and the coax and Ethernet cabling in conduits. Turned out nice I think.
   / Building a stick frame house in the woods in 90 days #2,169
if you have line of sight between the two houses you can get good distance out of commercial WIFI gear and directional antennas.
If you own all the property between the two homes, rent a trencher and run your own dry pair.
   / Building a stick frame house in the woods in 90 days #2,170
Curious what you tried... I use a couple of Ubiquity Nanostations for a link to my inlaws place and they work very well but leaves make them very unhappy.
Aaron Z
36FT. B-Tek Centurion 100 Ton Digital Modular Commercial Truck Scale (A56858)
36FT. B-Tek...
2013 Ford Taurus Sedan (A55853)
2013 Ford Taurus...
(APPROX 15) 6" X 2" X 68" TUBING (A57192)
(APPROX 15) 6" X...
2022 CASE CX57C EXCAVATOR (A52707)
2022 CASE CX57C...
UNUSED SDLANCH SDLL60 STAND ON SKIDSTEER (A57192)
UNUSED SDLANCH...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
