Building a stationary motorcycle lift in my shop.
   / Building a stationary motorcycle lift in my shop. #1
blackrams
Frankfort, KY
Ford 1210
I have an idea to build a stationary motorcycle lift in my shop. Yeah, it can and will be used for other things. Thought I'd run it by those who may have some experience with such things.
First, this lift will have it's base set into concrete deep into the soil inside my shop. The intent is for it to be free standing and not dependent on the actual shop structure to lift, hold and maintain the load. This will entail or require me to cut the concrete floor and remove concrete, fill gravel and three to four feet of soil. This lift will be a pedestal style, one post and a table to ride the bike up on nose first, secure it and lift.
Planning on using one of those 2K lbs electric winches run over a top pulley to the lift table to raise and lower with safety cogs or pins to hold in place while in use. I've previously had a motorcycle lift table, it simply took up too much valuable floor space.
I have 12 foot ceilings in my shop. I want this to be self supporting and not attached to the wall, but, up against or close to the wall. The lift table will fold up and be out of the way when not in use. We all know how valuable floor space is in a shop. I expect this lift to be able to handle up to 1K lbs. of weight easily but never over 1.2K lbs. so the chosen winch should be able to handle the planned load. My bike doesn't weigh that much but, once you have something like this, word spreads and all of a sudden you have friends you didn't know you had. :laughing:
My question is, what type of post should I use. I've considered I beam and heavy duty square/rectangle tubing but each presents it's own challenges as far as what kind of mechanism the lift table would ride on and, what type of bearings I should use. Any advice would be greatly appreciated.
BTW, I ride a Honda Valkyrie, 1520cc (horizontal or flat six cylinder) with lots of "safety chrome", one of the sexiest two wheeled machines ever built. ;) Any other riders out there?
   / Building a stationary motorcycle lift in my shop. #2
One of those flat hydraulic type lifts would be a lot easier to embed in the garage floor.
There's a thread on advrider from someone doing that, and a lot on lifts.
   / Building a stationary motorcycle lift in my shop. #3
Go dual purpose and get a used walk behind straddle type electric forklift.
That will lift that much weight easily and wheel out of the way when not needed.
Here is a forkover one for $1000 (forkover means that you have to use special pallets that have open bottom channels for the forks rather than standard pallets. Crown electric walk behind fork lift - business/commercial - by owner - sale
I paid about that much for a straddle type one that was self propelled.
Aaron Z
I have one of those air jacks like they used to use in shops and gas stations back when we all had metal bumpers. Was trying to make that work but, it didn't pan out. It's rated at 5K lbs. and will lift that but, that's with a straight lift. Adding the table to this air jack caused it to put too much pressure on the air cylinder when in the higher positions and the piston would "lean" toward the weighted side of the jack. Would still go up but wanted to catch coming down. This resulted in (during our test lifts) the bike to be hanging up and then dropping like a rock 6 to 10 inches.
Well, that just ain't gonna work. I've got a lot more money in that motorcycle than I do in my tractor. Lots of safety chrome and safety chrome is expensive. ;)
Reference the other ideas. Appreciate them but, if it takes up usable floor space, it won't work for me. With what I'm purposing, if the table is not in use, the table can be folded up and in a raised position thereby only taking up about six to ten square inches of floor space.
   / Building a stationary motorcycle lift in my shop. #5
Ah, how about this one: Stair Climbing Appliance Dolly w/removeable Forklift - tools - by owner - sale its rated to lift 1200# and should be much smaller when not in use.
Aaron Z
   / Building a stationary motorcycle lift in my shop. #9
If I understand this correctly, you plan to have the lift next to a wall?
That means one side of the bike is blocked. If you need to work on both sides of the bike, you're screwed.
Same problem with the various fork lift type suggestions.
Or do I misunderstand?
I have a scissors type lift that I repurposed. It was originally used in a cannery to lift totes full of cans. I modified it with a caster frame and jackscrews so I can move it around or use the jackscrews to lift the casters and have the bottom of the lift securely on the floor.
   / Building a stationary motorcycle lift in my shop. #10
Some details on my moveable lift here.
2019 Cat 914M Wheel Loader (A52384)
2019 Cat 914M...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
UNUSED CFG QH12R EXCAVATOR (A51247)
UNUSED CFG QH12R...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2023 John Deere 8R410 MFWD Tractor (A53472)
2023 John Deere...
