building a skid plate
   / building a skid plate #1
usmc5595
Bronze Member
Does anyone make or has anyone seen a skid plate made for the 5103,5203,5303 or the 5403 two wheel drive models with a front end loader. I am looking to build or buy a skid plate for the tractor.
I want the skid plate to go from the front of the oil pan where the front end loader bolts up to the rear axle. It will need to be braced in the middle. I may brace it at the rear bolt area of the front end loader as well.
Thanks in advance.
   / building a skid plate #2
hi i have made a few skid plates for my 4x4 farm tractors 5 all together .they are made of 1/4inch steel plate cut the width of the tractor allowing for turning and front axle movement, welded straps on the sides with drilled holes to bolt grade 8 bolts to tractor where needed , works good only thing is you need to cut hole for oil draining , we built ours in our shop good luck
do you have any pictures of the builds?
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2020 Bobcat S850 Skidloader (RIDE AND DRIVE) (A50774)
2020 Bobcat S850...
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
2007 Freightliner School Bus (RUNS) (TITLE) (A50774)
2007 Freightliner...
Safety Basket (A50121)
TRUCK FLATBED (A52472)
