Building a Garage
/ Building a Garage #1
KubotaSteve
Platinum Member
eastern panhandle of WV
Kubota B7800 with loaded R-4s
I'm getting ready to get started on my garage. I'm trying to figure out what I need to use for a header over the garage door. I am trying to decide between using a 16, 18 or 20 foot door. I'm figuring I'll have to use a LVL but I'm not sure of the size and can't find a lot of info on the web. Any help would be much appreciated. The county isn't real helpful basically waiting until you submit your plan then rejecting it (they don't really like the do it yourselfers). Also any idea on the cost of these? I know they vary by area, but I'm trying to get a ball park figure.
/ Building a Garage #2
You will never regret having a door that is wider than necessary. I put two 9 foot wide by 10 foot high single doors on my new garage and have to be really careful to get my truck in the door. If I had it to do over I should have gone 10 foot x 10 foot.
/ Building a Garage #3
I work directly with the local lumber yard, tell them what I am doing and they have an engineer who can spec it out and then give me price options. Sure beats guessing.
/ Building a Garage #4
Depends on if your talking the gable end (non-load nearing) or under the eaves.
When I built my garage, the local truss manufacturer (Manion in Superior, WI) also manufactured lvl beams. They had an engineer that talked me right through the process, it went slick as snot on a door knob.
There's probably someone similar in your area. Ask your lumber yard who builds their trusses, they may be able to help.
/ Building a Garage #5
Why do you want a 16ft, or wider door? Is this a two car garage just for auto's? If so, then allot of homes, millions, were built with two 2x12 and half inch plywood sandwiched between them. It's not code in some areas anymore, but those homes have lasted decades with those headers in them.
Over 16 feet, I would only use a glue lam beam. Price isn't that bad in the overall scheme of things. I think I paid around $200 for the last one I bought. It was 24 feet long and if I remember correctly, 14 inches tall. They come in standard lengths and you cut them down to size.
Lowes, Home Depot and just about any building supply store sells them. They don't stock them, but will sell them to you from the local company that builds them. Here, there is one company that does this, and all the building stores sell the exact same beams. Markup is different for each store, but not a huge difference from what I've seen ordering from three different stores.
They are very heavy, so expect to use a lift to get it into place. I've done them by myself with a hand operated lift. Rental of the lift is just $40 for hald a day and I've never needed one for more then an hour. The lifts look kinda like a hand truck with forks on the front. You crank the handle and up goes the beam. Real simple and easy with a little planning and prep work.
If you plan on putting your tractor in there, you really don't want a standard garaged type door. You didn't mention this, so it might not matter, but I've found that a 10x10 roll up door is just about perfect. Bigger is always nicer, but not really needed. My previous shop had a door 12ft wide and ten feet tall. That ten feet height was awesome. Twelve feet took away from space for the man door and made things kinda tight. On my current shop, I put went smaller and don't regret it at all. I was able to put my electrical panel between my man door and rollup door, which make it real nice to get to. Nothing blocks it!!!!
I also found that 12 foot walls make a HUGE difference compared to 8ft walls in most garages. That extra height makes working on things, building stuff and just plain old storage allot better.
Let us know what your usage is for the garage, and how big it will be, and we can offer suggestions that you might not have considered.
Eddie
/ Building a Garage #6
Depends on a lot of particulars and the size of your garage, but for me, 2 large doors like the 10x10 that was mentioned would be preferable over 1 huge 20 foot wide door.
I've never been a big fan of those single extra wides though I did just put a 14' wide x 8' high in my tractor shed, that was the opening that was there.
/ Building a Garage #7
I used a simple barn plan, like the ones available here Horse Barn Plans, Blueprints
A set of plans are under $100 bucks and will go a long way towards getting a building permit and somewhat engineered plans.
A small investment, for a long term structure like a garage.
Jim
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
John Deere 5075E Tractor w/ John Deere 520M Loader (A64047)
John Deere 5075E...
2500 GALLON INDUSTRIAL TANK (A62130)
2500 GALLON...
UNUSED LANDHERO CHAINS & BINDERS (A62131)
UNUSED LANDHERO...
UNUSED KJ 25'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 25'X12'...
2024 John Deere 8R 410 Tractor (A63109)
2024 John Deere 8R...
