Building a drag/harrow and comments welcome
   / Building a drag/harrow and comments welcome
Here's a couple showing it working on less trashy ground after I'd flipped it over. Much nicer Less Surface Trash.jpgConnection.jpg.
   / Building a drag/harrow and comments welcome #12
Center picture; what's the purpose of dragging?
These are food plots that are old pasture originally tilled using a 3 pt tiller. I am trying to use the field cultivator now instead. That leaves the surface too rough, furrowed, for planting clover, alfalfa, turnips etc. that are supposed to be planted on a smooth, clean surface and then cultipacked. The dragging gives me that surface.
If I was planting corn or beans by broadcasting I think it would work to use the field cultivator, broadcast, and then drag to cover.
I think I'll be able to use the cultivator and the drag at the same time rather than separately. Or the tiller and the drag although the tiller leaves a better surface. With the tiller I would till with the packer attached, then seed, then roll it again. Works great on small seeds.
   / Building a drag/harrow and comments welcome #14
Go get a diamond harrow. It'll do what you want.
   / Building a drag/harrow and comments welcome #15
Here's some photos. When I first put this to work it grabbed a bunch of dirt and grass so I flipped it over thinking I might have it "upside down." I see the original builder had it this way but for me it picked too much trash. When I have a cleaner plot I'll try it the other way. Don't know how many photos I can load.
I find that sometimes going faster works better, as it collects less trash. It tends to bounce more which drops the collected trash. So often I pull mine with a truck, going faster than i go in a tractor, circling the food plot making multiple passes. Often i have a buddy follow me pulling the drag as I'm disking ahead of him. I even tow it around the property with my truck smoothing the roads. Try it with a vehicle.
Sent from my iPad using TractorByNet
I'll give it a try...makes sense. Since this was the first outing and I was using the least expensive chains and connectors I could buy, I was being careful lest something gave way. But it all seemed solid. I used my Jeep to pull the cultipacker so this would be similar. Although I think using the tractor/cultivator/drag combo will work good too.
2014 FORD F-250 (A50854)
2014 FORD F-250...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
1995 Olympian Generac 94A06155-S Generator (A49461)
1995 Olympian...
2004 Dodge Ram 1500 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
CRESCENT  MANIFOLD TRAILER (A50854)
CRESCENT MANIFOLD...
