building a 3 point disc
   / building a 3 point disc
made hanger brackets 3/8 x 6 x 13 high, gonna chop off back half
is the 33.5 from spud end of axle to the start of the threads of the end of threads,, sorry only want to have to order once
   / building a 3 point disc #13
End to end total overall length. Lay a tape measure on the table and start marking 5 blades 7" apart if you get parts from agri supply. Ken Sweet
   / building a 3 point disc #15
frame is done
Excellent work. If I could make a suggestion? If I were building it, I would cap off 1 end of the square tubing and pour sakrete or old scrap bolts and nuts down the other end and then cap it off. More weight is better. Ken Sweet
Thanks ,Thats 1/4 tube the frame has some weight, going to use 39 1/2 axles 6 disc's each side.
To add weight going to use train rail @ 119 lbs pr foot. I really am looking to disc 2 to 4 inches after that rocks start growing lol
   / building a 3 point disc #17
finished handle, should have made lower 3 point attach plat from one piece, welded single tab then added top and bottom plates, was tired
   / building a 3 point disc #19
Just to help you when adding your weight, Railroad rail is weighed in 3ft sections. Most likely your 119lb rail is per 3 ft and not per ft
SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-2PS...
1265 (A50490)
1265 (A50490)
2017 Nissan Titan SV Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
2008 FORD F-750 (A50854)
2008 FORD F-750...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
