Building 6-7 foot disc from large disc.
   / Building 6-7 foot disc from large disc. #11
He specifically said he wanted 7 foot. Not that he couldn't pull more.
Yea, I read that already. I am inquiring as to why he only wanted 7', which seems kinda small for the tractor. Tight areas? Maneuverability? Indeed plan on building a second 7' unit? Really tough ground? Want to maximize penetration?
Several reasons why he might have did what he did. But I would think the tractor could easily handle 10-11'. My MX handles a ~11' JD210 transport disc. So I was wanting to know why he decided to settle in on 7'
   / Building 6-7 foot disc from large disc. #12
I think he did just fine.
I like your heavy frame and you can see the result by your blade depth. You seem to be in sandy loam which helps your penetration.
I had a pretty heavy frame on mine but added 4 JD rear wheel weights (600#) which helped penetrate my Houston Black Clay.
With that rig and my 6530, B-1 or 2 is all it wants. I think you are sized right for that tractor.
   / Building 6-7 foot disc from large disc. #13
Food plots , maybe a narrow entrance ?
   / Building 6-7 foot disc from large disc. #14
Yea, I read that already. I am inquiring as to why he only wanted 7', which seems kinda small for the tractor. Tight areas? Maneuverability? Indeed plan on building a second 7' unit? Really tough ground? Want to maximize penetration? Several reasons why he might have did what he did. But I would think the tractor could easily handle 10-11'. My MX handles a ~11' JD210 transport disc. So I was wanting to know why he decided to settle in on 7'
He specifically said he needed it for smaller plots.
I've been off the forums for a while! Didn't even realize had several replies on this thread. Yes, the Branson will pull a larger disc than that. I've pulled a 12 foot lighter disc. That old IH disc would have stopped it in its tracks! It would make my 1256 blow black smoke! I wanted a heavy cutting disc for new small plots and hard to get to areas. It fits the bill perfectly. I also love fabricating, so why not! The ground in the following pictures was hard as a rock! 20161002_162818.jpg20161002_162843.jpg
20160410_174415.jpg Pulling the 12 foot.
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
Bucket (A55973)
Bucket (A55973)
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
500BBL FRAC TANK (A58214)
500BBL FRAC TANK...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56436)
2019 Krause...
