Building 6-7 foot disc from large disc.
   / Building 6-7 foot disc from large disc. #1
Helitech
Aberdeen, MS
5220R Branson, 1256 International
Did a little horsetrading for a family owned 485 IH disc. I want a 6 or 7 foot disc to pull behind my 55 hp Branson. Repaired a tractor and gave $400 for the old disc.
After some quick measurements, I broke it down, most of the work was just unbolting pieces. Did a few trial runs with 2 of the gangs bolted under the center and it worked great! Biggest challenge was moving the wheels inboard a good bit. She's a heavy disc for the size! Ended up with a 7 foot cut with the offset.
As a bonus I still have 2 more gangs to build a heavy offset 3 point disc with.
Couple more pics.
   / Building 6-7 foot disc from large disc. #5
Nice job:thumbsup:
About 6 years ago I bought a 14 ft tandem axle wheel disc from my tractor dealer ($600 delivered).
Cut it down to 8 ft. Nice 4 day project.
Wheel disc delivery-2.JPGWheel disc mod-1 (2).JPGWheel disc modify-2.JPGWheel disc modify-3.JPGWheel disc on 5525.JPGWheel disc pintle hitch.JPG
Good luck
   / Building 6-7 foot disc from large disc. #6
I think the underlying problem is that the tractor is undersized/underhorse powered for a 14' disc. So, would a solution be to leave the disc width the same, but make shallower depth passes with the tractor, and then make another pass at a deeper depth? I am not questioning anyone's decision, I want to learn. thanks, Carr
No underlying problem. I already have a 14 foot disc and 125 hp tractor to pull it with. I needed a good 7 foot disc for smaller plots, a new one like I want is very expensive! Built on for 1/7 the cost of a new one!
   / Building 6-7 foot disc from large disc. #8
Good solution, I'm another that would like to have a good, heavy 7-8' transport disc.
   / Building 6-7 foot disc from large disc. #9
For the ground you were working, you don't think the 55hp Branson could have pulled it? Or perhaps only drop down to 10-11' by just removing the outer pans?
Unless you want a small disc for tight areas. I would think the Branson could handle a good bit more than 7'
   / Building 6-7 foot disc from large disc. #10
He specifically said he wanted 7 foot. Not that he couldn't pull more.
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
5' SCRAPE BLADE, 3PT (A52708)
5' SCRAPE BLADE...
(3) WEEDEATERS (2) GAS POWERED AUGERS (A58374)
(3) WEEDEATERS (2)...
2016 Ford F-250 Knapheide Service Truck (A56858)
2016 Ford F-250...
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
LOT: Fuel Transfer Tank, Tool Box (NO PUMP) (A59076)
LOT: Fuel Transfer...
