Building 55' Bridge Across Creek - Utility Poles
   / Building 55' Bridge Across Creek - Utility Poles #101
That is wonderful work. We have a similar size creek and I've been thinking about a walking bridge over it.
The permitting process can be a bit daunting in some areas.
If you were to do this job again, is there some tractor, attachment, or even a more specialized machine that would have made the job easier and more enjoyable?
BTW, on the use of linseed oil for protection, what you are describing with your the boiled linseed oil and turpentine mixture should work - although it may be slow to cure (self-polymerize). That mixture is not to far removed from a harder natural oil varnish - which I made up in bulk when we built our house & learned some tricks in the process.
rScotty
   / Building 55' Bridge Across Creek - Utility Poles #102
rScotty
Re linseed oil:
I used that to treat the logs on a log cabin years ago.
As time went by the logs all turned black.
What I later learned was that I should have added a 'fungicide' to my oil mix.
OK, for a bridge black is OK, I guess!
Oh, and the difference between 'raw' and 'boiled' linseed oil is boiled is supposedly treated with driers or hardeners while the 'raw' is very slow dry.
"Raw' will penetrate better=better long life protection while 'boiled' will harden and skim like paint on the surface.
For the treatment process - I have seen the application of a DIY mixture used on a trl deck, it is going on mine as well as all of my yard hand tools (wooden handles). The mixture is 1 part diesel and two part (used) oil (transmission, hyd etc). There will be some odour issues for a short spell however, I can sure attest to the use of diesel, it has been my go to for years for treating my leather boots.
Thank you. What is a sufficient amount of time to wait before treating? The oak was pretty green when I put it down.
rScotty
Thank you. This project did not require a permit :).
The bridge is a little over a quarter mile from my house, so the only thing that would have made it easier would have been a road to the site wide enough to pull a trailer. This would have made getting the material there much easier. The only other thing I might have done would have been to build some rock retaining walls along the stream banks on either side of the creek BEFORE building the bridge. I am in the process of doing this now with sandstone, of which we have LOTs on the property. It wasn't required, but it will keep the stream banks from eroding over time and make for a clean area. Other than that, It was just a matter of taking it day by day and humping the material back there. It was strictly a weekend project, but if I didn't have a job, it may have gotten done much faster :).
To give you an idea of the trail size leading up to the bridge, I will attach a few pics. The other two pics are a shot of the bridge from on top of the hill. Now that the leaves are beginning to fall, its a little easier to see from up on the trail.
   / Building 55' Bridge Across Creek - Utility Poles #104
Being as how it green wood, it really ought to dry for a couple years for any level of curing - but that is done under a cover - and that is for when one is going to use the wood in a furniture type project. A good hardwood like white oak would be okay to leave for the first year at least - those are big diameter and without it being split, the drying process is actually quite slow - a cheat for telling if it is dried out, is to look for checks along the log, checks in the end can happen faster but those are usually only indictive of being dry in to about 6 inches from the end - with the bark removed, I would judge that your wood should start showing signs of being sufficiently dry by the end of the first year
   / Building 55' Bridge Across Creek - Utility Poles #105
When I build with green lumber I want it to cure slowly.
That reduces the chance of warp, check, and splitting.
Best way I know of to do that is to paint the ends of the logs and boards with Anchorseal end sealer. It dries to a hard water resistant wax and really makes green wood cure better & last longer. You'll see it on high grade lumber ends too - especially hardwood. It goes on with a paintbrush.
Lots of articles about it if you google Anchorseal.
rScotty
   / Building 55' Bridge Across Creek - Utility Poles #106
Looks awesome! Personally, I'd want higher bumpers or rails. I can see my wife watching wildlife and driving the sxs off the edge. 😀
Thanks all, I will probably wait until fall to treat it. That seems like sufficient time to dry out.
We considered higher rails, but we like the open feel when walking/driving across. The bumpers are 4" tall and it would take a good deal of speed/power to jump it. My wife rarely drives the cart, so we should be good :D.
As a side note, I am surprised at how well the bridge is holding up to weight loads.
So far:
Golf Cart - 550lbs - no problem
JD z757 mower - 1050lbs - no problem
2 people, two horses, and a goat - 2200lbs - no problem
:D
   / Building 55' Bridge Across Creek - Utility Poles #110
Looking good!
I was thinking about doing the same. I have a creek with about 20 ft crossing plus footings etc.
I was hoping to take my tractor across, MX series.
I have a duke power easement for transmission lines and they are going to take down 2 tall wooden poles soon? For duke soon might mean 5 years.
I guess they are maybe 50 ft tall?
They said i could have them but.....
I don't have the manpower to do it so....who knows,
2025 Newrick JC25 Mini Wheel Loader Skid Steer (A55851)
2025 Newrick JC25...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
12" PIN ON BUCKET (A52707)
12" PIN ON BUCKET...
UNUSED LANDHONOR LHR-LB9510 LEAF BLOWER (A57193)
UNUSED LANDHONOR...
UNUSED FUTURE FT13 EXCAVATOR (A57192)
UNUSED FUTURE FT13...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
