Build a Zamboni
   / Build a Zamboni #21
Hi Fritzy,
Glad I could offer something - I'm usually just a benefactor from these boards!
Many times I've used 50 gallons or less. When building it I figured, I've got the tractor to lift it, so why not use it! It's when I am doing major repair to the ice that I will fill them completely - as many as 5 times. You've got to remember that even a full load of 110 gallons spread over my ice (~50X100') will only give you about 0.035" build up on average. Of course, it fills the grooves/ruts more and leaves less on the flat surfaces.
If I remember correctly, the holes are 1/8" and set 3" apart. Steel pipe should work fine since the water you'll have entering it will be warmer and will thaw it out when it enters it. Sometimes the holes on the stationary part of my boom freeze closed from the drips of water freezing from the last use. But as the water flows out to the boom extensions, they quickly thaw and things flow well. The boom extensions holes never freeze shut since I remove and invert the extensions as soon as I leave the ice.
Hope this helps!
Fud
   / Build a Zamboni
Thanks alot, I think I have all my supplies so I am going to stat building it this weekend, I will let you know how I make out. If my boys are around I will see if I can get them to do some pics.:)
   / Build a Zamboni
Well we just about got it built, one of my boys gave me a hand so it went pertty good, no pics they tell me the cameras not working. We will see if we can get something when we finish it up. Big storm coming in so we may not get back to it for a day or two.
I think this baby is going to work sweet.:D
   / Build a Zamboni #24
Keep us posted!
We had great skating this weekend and hope for a couple more weeks before thing start to get messy.
Fud
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
2014 Ram 1500 Quad Cab (A56858)
2014 Ram 1500 Quad...
