build a reservior for log splitter
   / build a reservior for log splitter #1
weavdog
Hello I'm a new member looking for some information on buying or building a log splitter reservoir,confused .Easier,cheaper or better.
Thank You
Weavdog
   / build a reservior for log splitter #2
Hello and welcome to TBN
You may want to post this in the "Build-it-Yourself" area.
   / build a reservior for log splitter #3
well the easyest way is to use a small beer keg and it can be mounted almost anywhere
   / build a reservior for log splitter #4
I used a empty 30 lb freon can.
An old empty cleaned out propane tank would work.
find dead air compressor tank
tom
   / build a reservior for log splitter #5
Weavdog: My store bought splitter uses a large square tubing boxed in on the ends for an oil reservoir. The square tube also doubles as an axle with the stub axles welded to the bottom.
   / build a reservior for log splitter #6
Shucks, any container that does not leak will do the job!
I once used a gallon paint thinner tin (square type) and soldered on a hose fitting to connect things up.
This was for a Jeep snow plow that was operated with a hand pump.
5 strokes and up, crack the valve and down. Worked great!
Naturally a tin can is not long lived as rust will attack unless you have a lot of oil leaks, LOL.
Virtually any container that is oil compatible will do the trick.
   / build a reservior for log splitter #8
Built mine from a gas tank taken off old commercial air compressor. One more vote for anything that holds oil. Read on another thread that volume should be 1.5 times pump's gpm. Maybe something to consider.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A60429)
2020 CATERPILLAR...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
1990 Bayliner 19ft Trophy Center Console Boat w/ S/A 20ft Boat Trailer (A59231)
1990 Bayliner 19ft...
2018 CATERPILLAR 320 EXCAVATOR (A60429)
2018 CATERPILLAR...
gps trailers (A56859)
