Backhoe Build A Backhoe For PT425... It Could Happen
   / Build A Backhoe For PT425... It Could Happen
Here's how it's gonna look with the boom attached. Missing from the picture is the box I have to fabricate to hold the pivot tube. The pivot tube box will be pinned through the brackets that I showed in the last picture. The rusty L shaped brackets that hold the boom will be welded to the pivot tube box.
Better look at that assembly. The pivot tube box will go between the brackets under the shiney washers.
It's gonna look like this extended.
And somewhat like this with outriggers. Missing is the dipper stick and bucket, of course. /forums/images/graemlins/tongue.gif
   / Build A Backhoe For PT425... It Could Happen #248
Moving along very nicely MR! /forums/images/graemlins/laugh.gif
   / Build A Backhoe For PT425... It Could Happen #249
/forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif $$$$$$$$$ ALERT!!!!!!!! /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
I was pre-warned that 1" I.D. X 1.5" O.D. tubing was expensive...... This is to confirm that it is.
5.5', that's 66" @ $29.00 per foot equals $180.00+ after tax!!
I found it locally and bit the bullet and bought it. Will measure twice and then measure again before cutting. /forums/images/graemlins/tongue.gif
Another thing to note. I took my 1" grade 8 bolt with me and found that it fit in some pieces of the tubing and not the others. The counter guy said the tubing has a manufacturing +- tollerance of .015". The one that they brought to the counter was -.005 and that was too tight for the bolt. They found one that was exactly 1" and it was snug but not tight. That's the one I took. /forums/images/graemlins/wink.gif He said if I have to order any more, they cannot guarantee that it will be the same size, so that's why I took the piece I did. I won't need that much, but figured if I mess something up, it could be a pain to find more locally less than 5' long.
So far my buget is right around $200.00 with the new tubing and the L brackets for the boom assembly from the junkyard. Also have a couple bucks in a bolt. Not too bad so far. The biggest expense will be the hydraulic valves and hoses.
I'm going to use those cylinders that I have at first. If they prove too weak, I can always get larger ones. I figure I might as well try it. The worst that can happen is that I'll have to torch off one mount for each one and re-weld in the proper location if I have to replace the cylinders with fatter, but shorter ones. Frugality rules for now. /forums/images/graemlins/grin.gif
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2002 MANAC 48'  WALKING FLOOR REFUSE TRAILER (A57880)
2002 MANAC 48'...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
