Backhoe Build A Backhoe For PT425... It Could Happen
   / Build A Backhoe For PT425... It Could Happen #181
David, how are things going with your backhoe. I just ordered a bunch of fittings from Hydraulichosefittings.com. I believe I am going to run those hoses inside the boom tube. I think the hoses will be protected more, and give a more cleaner look. Most backhoes I see, have hoses all over the place. I am planning to reinforce the hose connection points before I install the bulkhead fittings, Electric valves or manual valves, I am still debating that. Maybe a mixture would work out.
   / Build A Backhoe For PT425... It Could Happen #182
Good to hear yours is really making progress!
Manual valves for a BH. You need to have variable control on up to 3 spools at the same time.
I've had most of my free time consumed by family stuff! HELP!!! /forums/images/graemlins/tongue.gif
   / Build A Backhoe For PT425... It Could Happen #184
I didn't mean to imply manual valve. I meant lever/joy stick or electric valves., or even electric joystick. I should have been finished a year ago. It is amazing, that retirement does not mean retirement. Slowly but surely, I will have every thing put together. I was just at the hydraulic store, and learned that they will not crimp hydraulic cable and fittings that I bring in. /forums/images/graemlins/mad.gif They will make up hydraulic lines for you at so much per ft, plus fittings, plus labor. $40.00 plus tax for a 6 ft cable is steep. I can order it off the internet for about 1/3 to 1/2 of that price. I was hoping to cut hose to length, gather up fittings and Git er done. I have a crimping set, but have never crimped any thing. Their are some critical things to know before crimping. One wire, two wire, square hose cut, right amount of pressure. I thought it was crimp and go. Has any one used those screw on reusable fittings? It seems that I never stop learning. That 2 years of French I had in school was a total waste. Why didn't they teach me to weld and fix hydraulic hoses? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Build A Backhoe For PT425... It Could Happen #185
<font color="blue"> Their are some critical things to know before crimping. One wire, two wire, square hose cut, right amount of pressure. I thought it was crimp and go. Has any one used those screw on reusable fittings? It seems that I never stop learning. That 2 years of French I had in school was a total waste. Why didn't they teach me to weld and fix hydraulic hoses? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif </font>
Can maybe give a little advice, but not likely enough:
Burst pressure is going to be around 4X operating [thus your safety factor is already built in]. So a 2500psi hose will be fine even with 3ksi relief (espcially consering operating psi isn't going to be at relief - just a second every so often). There is some newer single wire hose rated at 3ksi, more flexible than 2 wire, handles the loads: no-brainer! Otherwise 2 wire should have no trouble, but I'd still check the ratings.
Unless you can get specs for your crimper (I wanted to buy one but the $$$s just didn't add up - espcially when I considered the same unknowns you're seeing) & dies, I don't know what to say. I know in really old dies were brand specific, then there were universal dies, but it seems now there are "new" style fittings using a new universal die.
The screw type looked a little bulky to me, but maybe it was my imagination. I still trusted a crimp more anyway. /forums/images/graemlins/crazy.gif
Pricing around here is a better than that, so I found an amiable solution to the crimping. I asked them if I could buy a total lenth of hose and the fittings (so I could cut and assemble in place) then bring them back for crimping. They had no problem, and I got about 5 hoses made for under $100. /forums/images/graemlins/smile.gif
   / Build A Backhoe For PT425... It Could Happen #186
</font><font color="blue" class="small">( I didn't mean to imply manual valve. I meant lever/joy stick or electric valves., or even electric joystick. )</font>
I'm not not quite sure which types you're comparing. I thought you meant a spool with a lever (or joystick) as opposed to solenoid activated spools.
If so, I said manual, because the solenoids I'm thinking of are On/Off which no ability to be variable. I think there are variable solenoid valves, but no idea of price or availability.
   / Build A Backhoe For PT425... It Could Happen #187
That price seems reasonable enough, but what were the lengths. I need 8 hoses for my backhoe.
   / Build A Backhoe For PT425... It Could Happen #188
Not today, but I can dig up the receit sometime; however, I recall the hose $ being small compared to the fittings. The crimp charge was maybe $1 or $2 (I think the former).
I was only running 2ft (and I think one 6ft) lenths, but it was 1/2". If you follow PT's design, you're fine with 1/4". I'd prefer 3/8" for easy flow, but the tighter bend radius is nice considering the scale we're looking at.
   / Build A Backhoe For PT425... It Could Happen #189
The hose cost was a bit more expensive than I thought. Even at that I can't imagine 1/4" being over 2/3 the price of 1/2".
$3.29 per foot of 1/2 inch high pressure single wire (Gates 70487). I only bought 5ft (I forgot I already had 4ft).
Crimp to 8JIC [straight] were $5.99 each.
The labor was only $1.00 each! /forums/images/graemlins/smile.gif
<font color="blue"> I've had most of my free time consumed by family stuff! HELP!!! </font>
Daughter's take Karate 2-3 days a week.
Father-in-law went in and out of hospital(O.K. now /forums/images/graemlins/wink.gif).
Brush hogging at property to prepare house site.
Daughter's first communion next week. Getting yard ready for big celebration.
Friends have new grand daughter.
Wife went camping.
Oh, yeah, I work, too. /forums/images/graemlins/tongue.gif
Keep the ideas, suggestions and comments regarding backhoe coming. I will use them all. /forums/images/graemlins/grin.gif
I am appreciating the hose and fitting comments greatly, as I haven't priced that part of things at all.
2017 Ford F-250 Pickup Truck w/ Liftgate (A56858)
2017 Ford F-250...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
48'' ALUMINUM MAN BASKET (A56857)
48'' ALUMINUM MAN...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
2011 John Deere 5085 70HP Utility Tractor (A55973)
2011 John Deere...
