Buick has a weird brake glitch
   / Buick has a weird brake glitch #11
GM doesn't have terrible brakes, and it's most likely sensor related, as mentioned, either a bad one or rust causing false signal./QUOTE]
My 2003 Pontiac Grand AM might not agree. :(
Fortunetly it found a new home after the brakes were redone for the third or fourth time.:thumbsup:
   / Buick has a weird brake glitch #12
You might have had a bad one, there might be models with bad brakes, but to say GM, Ford, Toyota, etc... have bad brakes is painting with an awful broad brush, that's all I'm saying.;)
   / Buick has a weird brake glitch #13
You might have had a bad one, there might be models with bad brakes, but to say GM, Ford, Toyota, etc... have bad brakes is painting with an awful broad brush, that's all I'm saying./QUOTE]
Don't think I mentioned any other makes.:)
My Y2K GMC still has OEM brakes, just had a tiny issue with the rust build up on the fronts. My '04 Lesabre should have gone a lot further than 49,000 miles on the OEM brakes but my wife used to drive it and she is the most terrible brake abuser, has no thought of coasting up to a stop sign, just roar up as fast as possible and slam them on hard. Our '04 Saturn still has OEM brakes with 52,000 miles, no issues.
   / Buick has a weird brake glitch #15
I don't think you did either, which was my exact point. GM specifically doesn't have bad brakes anymore than other make.
   / Buick has a weird brake glitch #16
I don't think you did either, which was my exact point. GM specifically doesn't have bad brakes anymore than other make./QUOTE]
A few years ago an Area represenative of a well known Auto Supply Store told me the GM brakes could be better. One thing he did mention was the senors clogging up or becomeing disabled.
I kinda figure the sensors are an integral part of the brake system.:)
A quik Google and seems I HAD company::( The replacement vehicle behaves very well.:thumbsup:
Brake or Rotor Problems? Premature Wear?
Have you or are you currently having problems with your GM, Chevrolet, Oldsmobile or Pontiac brakes or brake rotors? You are not alone! 1000's of other consumers have had to replace their brakes or brake rotors due to premature wear. According to Autoweb's Reliability and Satisfaction Ratings:
28% of Chevrolet Impala owners reported problems with their brakes or brake rotors. See Autoweb Report.
44% of Chevrolet Malibu owners reported problems with their brakes or brake rotors. See Autoweb Report.
And a whopping 51% of Oldsmobile Alero owners reported problems with their brakes or rotors. See Autoweb Report.
Some of the most common reported brake problems include: brakes squealing or grinding, brakes and/or steering wheel pulsing and rotors pitting, rusting, distorting, wobbling or warping. Many of these problems are due to excessive heat, rapid cooling. Additionally, the excessive wear and tear may be attributed to reports that an inferior metal composite has been used in the manufacture of the brake rotors, which were made smaller and thinner, and therefore, less able to absorb peak heat without problems.
What's most alarming is the frequency with which the brake problems reappear. After having their brakes and rotors replaced, consumers report the pulsing, grinding and squealing reoccurring within 3000 - 7000 miles, eventually leading to yet another replacement, which falls well short of GM's guideline of brakes being expected to last 12 months/12,000 miles.
The brake problems affect a wide range of 1997 - 2003 GM cars and trucks, including Chevrolet Malibu and Impala, Pontiac Grand Am and Grand Prix, Oldsmobile Cutlass and Alero and many other makes and models.
If you would like to know whether or not a legitimate claim for recovery under the lemon law is available to you, take a moment to read through this web site and send us your information. Or contact any of the attorneys listed. There is no cost or fee for doing so.
   / Buick has a weird brake glitch #17
Any brake job is 50% parts quality and 50% installation, after that no two are alike...environment plays a huge factor, do they go thru "touch less" washes with chassis wash? Were the rims cleaned with wheel acid? Do they like to shine their tires? Was the car driven over recently redone roads or other dusty abrasive conditions?...I could make a list a mile long but, the fact is brake life is relative to a million factors, something as seeming meaningless as the drivers bodyweight will affect the wear.
   / Buick has a weird brake glitch #18
First page I clicked had 8 Ford models with similar issues, 6 Toyota's and 6 Nissan's. Like I said, it ain't GM any more than anyone else.;)
1 example;
Ford Flex Problem
9 ReportsMe Too Edit Model Years Affected: 2009, 2010, 2011
Average Mileage: 27,000 mi (9,000 mi - 56,000 mi)
Verified
Defective anchor brackets for the front calipers can cause abnormal brake rotor and pad wear concurrently. Noise can be heard while braking, a grunting or grinding from the front. The caliper anchor brackets should be replaced with revised parts, and also replace the rotors and brake pads.
Club Car Utility Cart (A55853)
Club Car Utility...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
Sterling AT (A56435)
17101 (A55851)
17101 (A55851)
NEW Fork Extensions (A59000)
NEW Fork...
2010 GMC Seirra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Seirra...
