Buhlers
/ Buhlers #2
I like the way the engine is behind the rear wheels. Give you good lift capabilities for the weight of the vehicle. I bet it cost a little more than my PT422.
/ Buhlers #4
It looks like their drive pump can output 110% of rated horsepower.
Could it be that it can do either 6000psi or 21gpm?
Doing both with 100% efficiency implies 73HP, off of a 65HP engine...
PT seems to set the PTO HP at about half of the total HP.
Could it be that PT engineers in some HP to go up the hill AND drive the PTO at the same time?
All the best,
Peter
Hydraulic HP calculator
MrJimi said:
The specs are unreal even they are metric or imperial?
Wheel Loader - Buhler Industries Inc.
check out the hydraulic pressures :eek:
/ Buhlers #5
When you go to 45-50 HP or more, there's lots and lots of these machines to choose from.. Cat, JD, Kubota, JCB, New Holland, etc.
Try Googling "compact wheel loader" and you'll see what I mean...
Here's an interesting smaller line that keeps getting linked here, just starting to show up, coming from Europe...
Index
/ Buhlers #8
Only if the slope is less than ten degrees; more than that will push the lawn off... Can you say tippy?
Egon said:
Will that leave marks when mowing the lawn???:D :D :D
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
2021 Exmark Lazer Z 60in. Commercial Zero Turn Mower (A61572)
2021 Exmark Lazer...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
KOMATSU PC360LC-11 EXCAVATOR (A64279)
KOMATSU PC360LC-11...
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
