Buhlers
   / Buhlers #2
I like the way the engine is behind the rear wheels. Give you good lift capabilities for the weight of the vehicle. I bet it cost a little more than my PT422.
   / Buhlers #4
It looks like their drive pump can output 110% of rated horsepower.
Could it be that it can do either 6000psi or 21gpm?
Doing both with 100% efficiency implies 73HP, off of a 65HP engine...
PT seems to set the PTO HP at about half of the total HP.
Could it be that PT engineers in some HP to go up the hill AND drive the PTO at the same time?
All the best,
Peter
Hydraulic HP calculator
MrJimi said:
The specs are unreal even they are metric or imperial?
Wheel Loader - Buhler Industries Inc.
check out the hydraulic pressures :eek:
   / Buhlers #5
When you go to 45-50 HP or more, there's lots and lots of these machines to choose from.. Cat, JD, Kubota, JCB, New Holland, etc.
Try Googling "compact wheel loader" and you'll see what I mean...
Here's an interesting smaller line that keeps getting linked here, just starting to show up, coming from Europe...
Index
   / Buhlers #8
Only if the slope is less than ten degrees; more than that will push the lawn off... Can you say tippy?
Egon said:
Will that leave marks when mowing the lawn???:D :D :D
2018 JOHN DEERE 333G SKID STEER (A51246)
2018 JOHN DEERE...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
SCHAFFER 2430SLT LOT IDENTIFIER 114 (A53084)
SCHAFFER 2430SLT...
