Snow Equipment Owning/Operating Buhler snow blower fan replacement
   / Buhler snow blower fan replacement #1
Rustywreck
Solon Springs, Wisconsin
New Holland T 1520
Good day all,
I have a 60" Buhler snowblower with a three blade fan. I am attempting to replace the fan with a four blade.
It seemed like a straight-forward job: remove the one bolt, pull it off the shaft and put the new fan on. I was able to get the bolt out easily, but the fan will not come out of the shroud in which it turns. There is a small lip which it gets hung up on which prevents the fan from coming completely off the shaft.
I've tried rotating the fan in various positions, but I always have the same result.
Has anyone removed the fan from one of these blowers and have any suggestions?
Thanks for your help.
   / Buhler snow blower fan replacement #2
I haven't and so can offer you no insights on it ... but I have a 60" Buhler with a three blade fan myself, so I'd really appreciate it if you post again with whatever you come up as the solution ... ;)
   / Buhler snow blower fan replacement #3
I have a 78" JRW, and I have had the fan out several times even without removing the big auger. With your Buhler, you might just have to remove the bolts holding the gearbox in place and move the gearbox [ fan shaft ] forward some to give you enough room to tilt out the fan. When you take the fan off, or replace it... notice that there are usually washers put between the fan and the end of the threaded gearbox shaft. They may be real rusty and stuck inside the fan, but I bet they are there. These washers are there to adjust the clearance of the fan from the flat metal behind it and kind of semi-center the fan in the housing/keep it from rubbing. Good luck...... Jerry
   / Buhler snow blower fan replacement #4
If its a little out of round at an edge you can always use a file or something to smooth it enough to get past it.
   / Buhler snow blower fan replacement #5
Try disconnecting the chain drive and then turn the auger to suit. It worked for me. I had e heck of a time to get the fan to move initially, but once moved and properly lubricated it was much easier the next time.
Where are you getting the four bladed fan from - Allied Buhler ? If so how much are they charging if you don't mind me asking.
   / Buhler snow blower fan replacement #6
Yes ... and for anyone who has replaced their 3-blade fan with a 4-blade, a report on the difference in performance.
   / Buhler snow blower fan replacement #7
Good day all, I have a 60" Buhler snowblower with a three blade fan. I am attempting to replace the fan with a four blade. It seemed like a straight-forward job: remove the one bolt, pull it off the shaft and put the new fan on. I was able to get the bolt out easily, but the fan will not come out of the shroud in which it turns. There is a small lip which it gets hung up on which prevents the fan from coming completely off the shaft. I've tried rotating the fan in various positions, but I always have the same result. Has anyone removed the fan from one of these blowers and have any suggestions? Thanks for your help.
How big is the fan diameter? Mine is 18 inches and a three blade. I am in the process of changing the fan diameter to 24 inches and making it a four blade.
   / Buhler snow blower fan replacement #8
This is hijacking the tread a bit but I would like to see where the four blade blower comes from.
I was given a IHC 80 snowblower. The blower was completely wrecked and no longer available from IHC. Even though it was nla the price was $700. So I built my own. I took a 2' square piece of 3/8ths steel and had a machine shop cut a hole in the center for a browning hub. I cut four pieces of 6" channel iron for the blades. Weighed them so they were equal in weight. I also weighed all the braces and welding rod I used so that the blower would be balanced. Because I had used a browning taper lock hub the local tire shop could put it on their machine and balance it for me. I needed to add one ounce of weight to adjust the balance.
The blower shaft was also worn so I took the gear box apart and welded and filed the shaft smooth. I installed new seals and oil and the gear box was good to go again.
I sold the IHC 80 because I didn't have a tractor to run it and used the money to buy a front mount snowblower for my 4410. :)
So far I haven't had a chance to work on with it further - stinkin' job. I looked at it regarding removing the gearbox, and that method would more or less require disassembling the entire snow blower.
I don't know what the diameter of the fan is. The four blade fan was an option on blower I have, but mine came with a three blade. It is a factory replacement part.
Hopefully it will be a couple months before I can give a report on the difference between the two fans, but I certainly will. After last winter I'm not excited to see another snowflake.
It was a fairly expensive part, $250.
   / Buhler snow blower fan replacement #10
I just did a fan replacement on my new holland front snow blower, It was a big job as the augers, gearbox had to be removed. Pretty much just had the box and parts out in my garage. It was the only way that the fan would fit out. I also had to remove the reduction gear and bearing(which I damaged removing it since it was almost welded on there) Once I got the assembly off the old fan came off easy but the new fan was a tight fit. I thought it would be a 1/2 hour job but like any job ended up more like 3 hours.(after 3 days of waiting for new bearing to come in)
2015 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53472)
2011 New Holland...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53472)
2021 John Deere...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
